Read Disc Conversion
Old Sep 28, 2004 | 11:01 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Default Read Disc Conversion
I know its been covered tons of times in the past but I never get the information I need when I do a search. What all would I need to do a rear disc conversion on my 93 Civic EX?
Old Sep 29, 2004 | 12:07 AM
randomtask77's Avatar
randomtask77
Wanderer
Rear LCA's (easier if you just got the entire rear suspension setup, minus the spring/shock setup), Proportioning Valve, Master Cylinder, E-Brake lines. I got mine from a 91 teggy. Then replace the rear rotors and brake fluid lines (SS braided would be better) to newer ones.
Hit up either ManInCamo or the Doood for more info, they've done the rear disc conversion.
Old Sep 29, 2004 | 12:08 AM
Outxider's Avatar
Outxider
X-Motoring
94-95 integra/92-95 civic si/99-00 civic si(all the same) the rear trailin arms with the rotor, calipers. for ur civic u can reuse ur lca or the integras or aftermarket. get ebrake cables as well. im sure the integra or the si would work cuz u have a coupe. to make it even better, get the 94-97 integra RS mc and booster along with a 5g si without abs prop valve. all direct bolt on. its 15/16in. if ur lazy, get the prop valve and a 1991 civic ex mc, direct bolt on and no need for booster swap out.
Old Sep 29, 2004 | 08:05 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Thanks yall.
