Help! Problem with 1995 Civic DX.
Old Sep 20, 2004 | 01:39 AM
Steve90TTZ's Avatar
Steve90TTZ
Default Help! Problem with 1995 Civic DX.
My fiances 95 Civic has been giving us problems lately. It is detonating and also consuming approx. 1 litre per 2000km. I know that the oil burning problem is likely valve seals or rings. It has approx. 120000 miles. I did a compression test and the results seem to be fine. Do these cars have problems with valve seals at this mileage? I am really concerned about the detonating. I checked the timing and it is set perfect. Does anyone know where the egr valve is located? Could it be detonating because of a dirty fuel filter?
TIA,
Steve
Old Sep 20, 2004 | 07:58 AM
Hondaman's Avatar
Hondaman
Black Pearl
It might be the PCV valve. :dunno:
Old Sep 20, 2004 | 08:08 AM
Paul's Avatar
Paul
Eater of Rice
do a leak down test, it could still be the rings.
Old Sep 20, 2004 | 08:17 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Do a leak down and post the tesults of each cylender that will tell you if its valve seals or rings, also is it leaking any water, and whats the exhaust look like? And when you take the spark plugs out for the leak down, replace them with NGK and see if it helps anything. If it is a valve seal, dont drive the car untill you fix it, or you will burn up the valve seat, and then you need to take it to a machine shop (been there done that)...
Old Sep 20, 2004 | 11:35 PM
CivicJester's Avatar
CivicJester
what were your compression ratings? if your compression was in spec I would suggest a leak down test, let us know where you hear air leaking from so we could better assist you, my guess would be bad rings. there is no egr valve on any b or d series motor.
Old Sep 21, 2004 | 02:32 AM
Steve90TTZ's Avatar
Steve90TTZ
I don't recall the compression test numbers exactly, but I recall them all being within 5psi. I might need to do another test as well as a leakdown test. I pulled the plugs tonight and they were all white (lean). Could this be caused by a dirty fuel filter? I looked through the records and I don't see a receipt for one since we purchased the car (about 60,000miles ago).
Thanks for all of your input,
Steve
Old Sep 21, 2004 | 11:45 AM
Civic2Scooby's Avatar
Civic2Scooby
Steve
it can never hurt to replace the fuel filter, actually I would recomend it. If you dont know for a fact it has ever been changed than do your motor a favor and change it.
Old Sep 28, 2004 | 01:00 AM
Steve90TTZ's Avatar
Steve90TTZ
I did a leak down test last week.
#1-14%
#2-11%
#3-6%
#4-9%
How are the numbers for a 120,000miles? I also started running premium fuel and ran some combustion chamber package from BG products. It seems to be much better with almost no hint of ping.
Steve
Old Sep 28, 2004 | 10:13 AM
Civic2Scooby
#1-14%
#2-11%
#3-6%
#4-9%
Steve
where were the cylinders leaking? where did you hear the air hissing from
Old Sep 28, 2004 | 11:44 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
looks like somthing is out of balance, check your valve gaps, your cam could be rounding out....
