civic or transmission
Old Sep 19, 2004 | 06:27 PM
sharktlp's Avatar
sharktlp
Default civic or transmission
Today i was driving and all of a sudden it was real hard to put the car into 1st or 2nd gear. I pulled over and turned it off. When i turned it back on and hit the clutch the pedal stayed down. Is my clutch gone? Or can it be something with the clutch cylinder? I have a 93 civic ex 5 speed hydraulic transmission and an act 4 puck clutch.
Old Sep 19, 2004 | 06:56 PM
Twiz's Avatar
Twiz
Check your fluid for the hydro part of the system. It takes brake fluid and is located right next to the brake master cylinder.
Old Sep 19, 2004 | 07:02 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
curious why you have a 4 puck clutch?
check the clutch fluid, master cylinder and slave cylinder.
Old Sep 19, 2004 | 07:06 PM
sharktlp's Avatar
sharktlp
The car came with the clutch. Could the transmission be bad or was it so hard to get into gear because of the slave cylinder?
Old Sep 19, 2004 | 08:24 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
If the pedal just goes to the floor, I would say the clutch isn't fully disengaging and that's the reason it's resisting going into gear. Check your fluid system, there's a smaller master cylinder and resovour on the firewall between the fender and the brake MC. Make sure there's fluid in the resovour (it just takes standard DOT3 brake fluid) and follow the metal hardline across the firewall and eventually over the tranny and to a slave cylidner bolted to the front of it. Check for any leaks or wet spots. It's possible just one of those (the master or slave cylinder) is going south and not holding pressure, but it's also possible the pressure plate itself has failed and the clutch has nothing to push against.
Old Sep 20, 2004 | 01:42 PM
sharktlp's Avatar
sharktlp
Today I took a mechanic to check out the car. He was bleeding the clutch and the pedal did not come up. He said there was no leak and that the problem is the disc. My question is will it be safe to order just the 4 puck disc? or do i need to order a new pressure plate as well.
Old Sep 20, 2004 | 02:18 PM
asiandoood's Avatar
asiandoood
if you have nothing done to the car ...go with the street disc. you dont need a 4 puck. the 4 puck doesnt last long and is not suitable for daily driving.
Old Sep 20, 2004 | 02:36 PM
sharktlp's Avatar
sharktlp
if i get the street disc will a need a new pressure plate
Old Sep 20, 2004 | 03:00 PM
Andy's Avatar
Andy
It's most likely the pressure plate not the disk that has failed if the pedal's not coming back up, so regardless, you need a replacement. Do you know what pressure plate you were using (heavy duty, exterme ...). You might even consider contacting ACT and see if they would be willing to replace the thing for you, it's a long shot, but worth a phone call.
Old Sep 21, 2004 | 06:26 AM
SmartySarty's Avatar
SmartySarty
happened to me, just bleed the brakes and add fluid...................at least it fixed mine
