cluster remove question -
Old Sep 17, 2004 | 04:06 PM
drooby's Avatar
drooby
Default cluster remove question -
when removing the cluster on a 94 lx - the manuals talk a lot of mumbo jumbo about taking care of the airbag ..... and using short wires when working near it so that no open circuits occur.....blablabla
is this really necessary - i know that the three plugs into the top of the cluster have the SRS signal in them - so should I short circuit the SRS and disconnect the battery before removing the cluster ??
Old Sep 17, 2004 | 04:21 PM
cartuner's Avatar
cartuner
If you just uplugging and plugging the cluster theres no need to short the SRS system unless you're planning on doing some wiring work. But at least, disconnect the battery ground.
Old Sep 17, 2004 | 04:40 PM
drooby's Avatar
drooby
i plan to reamove it from the car , and put it back in ?
so only battery ...... this is a 94 accord?
Old Sep 17, 2004 | 04:57 PM
cartuner's Avatar
cartuner
Yeah, I have a 95 Accord and I had to replace the bulbs behind the cluster before and I had no problem without shorting the SRS. Just disconnect the battery. Good luck.
