nother noobie swap question
Old Sep 6, 2004 | 10:02 PM
SamuraiBill's Avatar
SamuraiBill
Default nother noobie swap question
Ok, I am swaping a B16a SIR II into I a 92-95 civic, and I want to know what needs to be done to the motor before I swap it??? The reason I am asking is that I know somethings are easier to do with engine out of the car so to save time and money I would like to know what needs to be done. I am trying to get 250-300 hp out of the motor. I want my car to be all motor no boost. Any suggestions?????????????? :thinking
austin :driving:
Old Sep 6, 2004 | 10:13 PM
CivicRacr's Avatar
CivicRacr
the timing belt and water pump usually. if you plan to get a new clutch and/or flywheel, also a good time to do that and any internal upgrades if you have the parts
Old Sep 7, 2004 | 04:34 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
:werd: I would wait to put it in car and do internals on engine stand if I were you.
Old Sep 7, 2004 | 08:33 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
its much easier to work on an engine while its off the car. so do all you can. as far as achieving 250-300hp all motor, youve got alot of work ahead of you.
Old Sep 7, 2004 | 01:27 PM
SamuraiBill
Thanks for the info is there anything else???
Austin
Old Sep 7, 2004 | 02:00 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Always sound advice. Unless you like benchpressing transmissions.
Old Sep 9, 2004 | 06:10 PM
HatchBackLove's Avatar
HatchBackLove
HatchBackLove
if you want that much power all motor youll need to do the bottom end up. pistons, bore,stroke,rods, bearings,water and oil pumps, plus head work. but if you want it in as is now just tune it up completely, with timing belt replacment, oil change, and stuff. but for that much power you need a ton of money and time. i have an ls vtec swap in my hatch running 235 hp at the wheels with a list of parts to get it there
