Manifold issue
Old Aug 29, 2004 | 12:22 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Default Manifold issue
Anyway I got the AEBS manifold installed, and its a royal bitch.
Anyway, when I start up car the RPM jumps up to near 4-6k and then I gotta turn it off for fear of redlining in neutral.
The only thing I can think of that is disconnected is the IATV, which is disconnected because the wires arent long enough.. which leads me to another question..
can I cut the wires and rewire them longer without screwing things up?
Old Aug 29, 2004 | 12:50 PM
Kabooki's Avatar
Kabooki
think after puttin a cai or header you gotta unplug battery so ecu can redetect all new mods
Old Aug 29, 2004 | 12:52 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
its more like a vacuum problem, but yes, you right , fuel maps change partially.
Old Aug 29, 2004 | 01:36 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
shivers had this exact same problem. Your manifold is not bolted on all the way or the intake manifold gasket or tb gasket is no good. It's just sucking air in and not using the tb plate to restrict the air flow. Double check that all of the bolts/nuts are tight on both the intake and the tb.
Sorry, that's :bs:
Old Aug 29, 2004 | 01:47 PM
Civic2Scooby's Avatar
Civic2Scooby
to answer your other question, yes you can cut them and lengthen them with no problem. I would recomend soldering the connections but it is not neccessary.
Old Aug 29, 2004 | 01:51 PM
westcoaststyle
Oh, I missed that part. :loco:
Ya, man. Just make sure you don't cross them over when you solder them back together. Do one at a time.
Old Aug 29, 2004 | 05:17 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
yep yep, I remember doing that once with tach.. never again.
anyway it wasnt bolted on correctly, it was *slightly* askew, im reinstalling now, I figured since I had to take off anyway I took off the old manifold bracket, it fit much better, ill update next time I try to turn it over
Old Aug 29, 2004 | 05:31 PM
westcoaststyle
I win! Thanks Tony! :joshers:
Old Aug 29, 2004 | 06:14 PM
Kabooki's Avatar
Kabooki
Sorry, that's :bs:
just what I heard somewhere, i dunno...
Old Aug 29, 2004 | 07:20 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
im so frustrated.
I redid everything , took out manifold bracket for extra extra room, and still the same thing.
tommorow im calling up AEBS, which I hoped I didnt have to do, because of the earlier thread telling me how bad their customer service is.
*sigh*
