need help b18c
Old Aug 28, 2004 | 02:06 PM
93delsoLb18c's Avatar
93delsoLb18c
Default need help b18c
I have a 95'b18c w/turbo, i have oil on my pistons all four,M compression is good. My exust smokes when i stat to drive,about 5min into drivin. what could be the problem????(BLOWIN OUT WHITE SMOKE)
Old Aug 28, 2004 | 02:34 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
bad rings?
Old Aug 28, 2004 | 03:40 PM
Civic2Scooby's Avatar
Civic2Scooby
I would also say bad rings.
Old Aug 28, 2004 | 08:12 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
if your compression is good, I would hesitate to call it rings. Its possible you have bad valve guides, leaking oil in from the head. Same thing happened to our old prelude pizza-mobile.
Old Aug 28, 2004 | 08:44 PM
Kai's Avatar
Kai
Rotorphile.
White smoke says water or coolant, as in a blown head gasket or a cracked head... but good compression would make that kinda weird.
Have you checked your coolant level recently?
Old Aug 29, 2004 | 01:34 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Is the smoke silver/bluish or definitely white?
Old Aug 30, 2004 | 08:09 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
5 minutes into driving would be about the time the thermostat opens...
sounds a lot like a blown headgasket to me.
