View Poll Results: which motor would you choose?
def b18b
16
72.73%
def b16a
4
18.18%
phuck all that and save up for a K swap....h:
2
9.09%
Voters: 22. You may not vote on this poll
boost b18b or b16a
Old Aug 26, 2004 | 11:01 AM
  #31
white_n_slow's Avatar
white_n_slow
it's my D in a B
in reference that the B16 head flows better than the b18c one...
The notion that the b16a head flows better than the b18c one is a myth. Both heads have distinct and different flow characteristics, but neither is inherently superior to the other. The overall volume of air moved by either head is pretty much identical.
That said, it may still be in your advantage to throw the b16a head onto the b18c because of the b16's increased combustion chamber volume... it will essentially lower the compression of the motor about 0.2:1.
Are you seriously considering just throwing a turbo on an internally stock motor though? Like I ranted earlier, once the power bug bites, you'll never be satisfied with a stock motor. Anyway, if I were to build a motor for turbo, I'd start with a b18c, bore to 84mm, and leave compression in the 9:1-10:1 range (sound familiar?) Using an LS crank would make a boatload more torque, but that would likely be power you could only use in 4th and 5th gear... And given the high wear tradeoff, I think the b18c crank is a better choice for a turbo motor.
Finally, don't use your motor, I want it! :fawk:
Old Aug 26, 2004 | 01:02 PM
  #32
Civic2Scooby's Avatar
Civic2Scooby
we shall see....we shall see....
so now all I need is the money and I am all set...:happysad:
Old Aug 26, 2004 | 02:40 PM
  #33
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally Posted by honda_pilot
I wouldn't run boost especially higher levels on a Honda without sleeves :dunno:
Did you miss the part where I was running ~300 whp on a nonsleeved C1 bottom end? h:
B18B. That is all.
Old Aug 26, 2004 | 08:12 PM
  #34
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Originally Posted by wambamcivic
Na, you get alot more out of the bottom end of the b18 than you do the b16 so it would be worth the effort
You get .2L of displacement. That's not a lot more bottom end.
Old Aug 26, 2004 | 08:15 PM
  #35
westcoaststyle
Sure seems like it when going from 1.8 to 2.0. :dunno:
Old Aug 26, 2004 | 09:00 PM
  #36
Jafro's Avatar
Jafro
I'm made of meat!
More displacement is ALWAYS better, especially if you're going to work the block anyway.
Increasing displacement makes your turbo spool like crazy, thus giving you the power earlier, and improving throttle response. Hmmm.... Nah! Can't be having any of that.
