Im ready!
Ok I have a 97 hatch dx, 96 B18C1 motor and tranny, all Si mounts, Complete wireharness(already done for the swap), Linkage, ECU, axels, headers, clutch pedal(im gonna grind the stock brake pedal so I don't have to go through the trouble of swaping it for the 5 speed one). I know what I have to do.only issue I have is how will I be able to start the car once everything is in? I know there are 2 cables I have to jump on the plugs where the auto gear shifter was but I don't know what 2 wires :thinking: Can someone help?
if you want the 97 hatch wires for the auto setup... the blk/wht & blk/red wires should be run to your clutch switch. connect them to be able to start the car.
but it really depends on which ECU you are using, those wires may not run to the right pins....
