Engine ping
Old Aug 23, 2004 | 07:25 AM
sers's Avatar
sers
Default Engine ping
Hi all.
Got a small problem with my 1993 Civic Si (EX in the US). THe car is completely stock, BTW. Between 1000-4500 no engine ping, after 4500, the engine starts to ping / knock like mad.
I use 87 octane, tried 91, no change.
Any fixes for this? Is it the timing? If so, can someone tell me how to set it properly?
Thanks.
Old Aug 23, 2004 | 08:02 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
buy a hanes book to learn how to do the timing. i am not saying that that's the problem though
Old Aug 23, 2004 | 09:34 AM
honura's Avatar
honura
Seni
Is it like a small knock? Or a knock like you know something is smaking in there? If it's the second one then your throwing a rod. If it does it in neutral then you can find out which one it is you can pull one spark plug at a time and see if it stops if it does then you know that's the one.
:edit: I don't know what ping is. :thinking:
Ohh and KAUAI KANE that book will not tell you what the hell that is.
Old Aug 23, 2004 | 10:08 AM
sers's Avatar
sers
Well, I guess the term knock was the wrong one. It sounds like a typical engine ping. It doesn't knock at idle or if I rev it or anything like that. Just after 4500 rpm, it sounds like a blender with a bunch of bolts in it rattling around.
Old Aug 23, 2004 | 10:28 AM
honura's Avatar
honura
Seni
so your gonna blow a rod.
Old Aug 23, 2004 | 10:56 AM
supermac88's Avatar
supermac88
not OG but Old School
Or your valves could be way out of adjustment, or your timing could be off, or you could have a rod knocking. It could be lots of things, hell for that matter if you didn't really know much about cars you could have a bad axle, you might laugh but I have seen it happen.
Old Aug 23, 2004 | 02:47 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
1. make sure your oil level is fine.
2. check timing.
3. check fuel pressure
4. use oil/fuel additives to clear carbon deposits
then get back to us!
Old Aug 23, 2004 | 04:13 PM
Human Hybrid's Avatar
Human Hybrid
Try the supreme fuel...93 i think...and check the timing...
Old Aug 23, 2004 | 04:26 PM
Jafro's Avatar
Jafro
I'm made of meat!
Could just need a tune up.
Looking at the plugs could help if you have the service manual or a chart to compare them to. They're a great place to start if you're looking for an indicator of some kind to point you in the right direction.
