lifespan of stock catalytic converter
Old Aug 17, 2004 | 12:45 PM
civicfan8's Avatar
civicfan8
Default lifespan of stock catalytic converter
Hi all,
I was wondering what is the expected life span of a typical catalytic converter on a 96 d16y8 civic? How do you know when a replacement is due?
Thanks.
Old Aug 17, 2004 | 12:48 PM
saga's Avatar
saga
broke college kid
It should last forever, or until it rusts so much that it disintegrates. You shouldn't need to replace it.
Old Aug 17, 2004 | 02:04 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
thats not nesc true... if yours O2 sensor goes out causing an incorrect A/F mix, then that can ruin it.
Old Aug 17, 2004 | 02:06 PM
saga's Avatar
saga
broke college kid
Well, it's not like there is a set mileage that you have to change it at which is what it sounds like he's asking.
Old Aug 17, 2004 | 02:22 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Yeah thats true. Guess I misread
Old Aug 17, 2004 | 05:44 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
If your car is running too rich you can go through a cat in a year or two. But yeah cats should last as long as the car.
Autocross Help Page
Old Aug 18, 2004 | 07:07 AM
wilsel's Avatar
wilsel
160K on my stock cat. I still pass emissions with less than 25% of the allowable readings (knock on wood). It all depends on how the car has been maintained.
Old Aug 18, 2004 | 08:56 AM
civicfan8's Avatar
civicfan8
Thanks to all....reason why I asked is that mine is now at 240k, and it barely passed the NOX when I took it in for a smog check at 230k, but the other two readings of HC/CO were very good, just the NOX that was just right at the border....so I have been thinking about replacing the catalytic conv. before the next smog check is due in like 2 years....just doing some research now. I live in CA btw...
I guess I should not have done this, but I poured a bottle of fuel injector cleaner into the gas tank like right before the smog check. Wonder if this could have caused a temporary high NOX reading....
Thanks again...
Old Aug 18, 2004 | 11:46 AM
92eg6's Avatar
92eg6
99 CG3 Owner
read my sig, i passed MD emissions with flying colors, with 2 1/2 piping a resinator as a High flow cat lol, and headers.
Old Aug 18, 2004 | 01:16 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
california..
yeah.
