Need Stronger Head Gasket For D16y8 Turbo
Old Aug 16, 2004 | 01:26 PM
reddemon009's Avatar
reddemon009
Default Need Stronger Head Gasket For D16y8 Turbo
I keep blowing my stock head gasket on my d16y8. im running 10 psi i want to put a after market stronger and thicker head gasket on. wat companys make a gasket for this motor? thanks
Old Aug 16, 2004 | 01:32 PM
XCM828's Avatar
XCM828
stay off of wet roads
try this...http://www.horsepowerfreaks.com/defa...ategoryCd=HGAS
Old Aug 16, 2004 | 01:40 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
you should stick with oem head gaskets and get some head studs...
also check your head and block's mating surfaces for warpage
Old Aug 16, 2004 | 07:39 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I run a cometic head gasket. I'm very pleased with it.
You SERIOUSLY should get some head studs too since you have to take the head off anyway.
hih
Old Aug 17, 2004 | 11:59 AM
reddemon009
how thick is your cometic head gasket?? i want it thick enough to lower my compression a half point may b a lil bit more so i can run more boost. thanks
