help....Vtec
Old Aug 3, 2004 | 08:39 PM
94civic's Avatar
94civic
Default help....Vtec
hey u guys i have a non-vtec civic right now. i got it when i was thirteen and i want to do a motor swap, im not new to this. but i havnt ever done work on a car with vtec. the motor i want to use is a DOHC vtec b18/ or k20 and if i have problems with vtec what should i do. and also, how can i tell if the vtec engages, like a spike in oil pressure
Old Aug 3, 2004 | 09:46 PM
saga's Avatar
saga
broke college kid
I don't have a VTEC either but from what I've read here you'll be able to hear the VTEC when it engages. That's an answer to one of your questions.
Old Aug 4, 2004 | 10:20 AM
Kai's Avatar
Kai
Rotorphile.
You don't really have "problems" with VTEC, either it works or it doesn't. If it doesn't, it will usually be a wiring problem.
If it stops working or sometimes works, check the ECU for problem codes. If the ECU doesn't send the VTEC signal, it will tell you why.
Old Aug 4, 2004 | 10:28 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
First, it will be damn near impossible to get a K20 into your 94 civic (well, not impossible but be prepared to spend insane amounts of money).
A B18c (either GSR or ITR) would be a good swap for your civic because it pretty much just drops in.
A VTEC motor is not much different than a normal motor. There is really nothing special about it and it isn't something that just "breaks".
Usually you can hear VTEC engage. Your car will sound like this:
vrooooooooooooommm *VTEC hits* BAAAAAAAAAAWWWWWWWW :rofl:
Old Aug 4, 2004 | 12:06 PM
94civic's Avatar
94civic
alright thnx guys, ya i probably will go with the B18, i just kind of wanted to keep the motor stock and do intake exhaust, then do fuuull out suspension. so i think your right the b18 will be perfect power upgrade. peace
