Whats a good way to Build...
Old Jul 27, 2004 | 06:15 AM
teg92's Avatar
teg92
WHAT OK YEAH!
Default Whats a good way to Build...
Whats a good inexpensive way to build horsepower and torque??
I have a 98 Honda Civic DX with an B18b1
ANy suggestions
Old Jul 27, 2004 | 07:36 AM
saga's Avatar
saga
broke college kid
Bolt ons.
Old Jul 27, 2004 | 07:42 AM
Quikstep's Avatar
Quikstep
OG Swollen Member
There is no inexpensive way. You already have the swap, so either bolt-ons or FI. Or NAWWWSSS
Old Jul 27, 2004 | 08:27 AM
Kai's Avatar
Kai
Rotorphile.
Raise the compression.
Old Jul 27, 2004 | 09:38 AM
Jafro's Avatar
Jafro
I'm made of meat!
It doesn't cost that much to boost an LS motor when you consider the gains.
Old Jul 27, 2004 | 10:01 AM
teg92's Avatar
teg92
WHAT OK YEAH!
how do you raise the compression?
Old Jul 27, 2004 | 10:16 AM
Jafro's Avatar
Jafro
I'm made of meat!
Change the pistons or deck the head. The first method mentioned is the best method. There comes a point when it limits what fuel you can use. I wouldn't ever go higher than 10.5:1 on a daily driver, and you'll be stuck needing 93 octane or better the rest of your car's life.
Old Jul 27, 2004 | 11:11 AM
saga's Avatar
saga
broke college kid
Might be a noob question but why do you HAVE to use the higher octane gas with higher compression engines?
Old Jul 27, 2004 | 12:04 PM
Quikstep's Avatar
Quikstep
OG Swollen Member
Otherwise you get
Knock Knock
Who's there?
BOOM hnoes:
Maybe not today, maybe not tomorrow, but one day, he'll be there.
Old Jul 27, 2004 | 01:35 PM
Jafro's Avatar
Jafro
I'm made of meat!
Because higher octane fuels keep detonation under control. Gasoline is ony stable in a certain compression range. If it exceeds its maximum safe pressure, it will pre-ignite causing knock/detonation. That's bad because it will blow your engine apart and melt pistons and valves.
Some fuels like Diesel and kerosene have much higher compression limits with low octane, but they rely solely on compression to ignite. Those engines don't have spark plugs, and achieve compression ratios higher than 50:1. The rods look like a cow's leg bones, and the bolts that hold them together are like trees in comparison to what's inside a Honda.
Some race motors are built 11.5:1 and are still streetable, but you won't get a B18 to run like that. I'm not sure it would stay together. What it would cost to make it do that in machining, you might as well bolt on a turbo because the stock compression on an LS motor is already turbo-friendly. Adding compressed air to the fuel mixture raises your engine's final compression ratio, in effect, doing the same thing, but adding more air and fuel, and in the long run, making more power.
You gotta run high octane fuel with a turbo, too... but you're not limited by your compression, you're limited by your tuning as to how you get away with running what gas.
