'93 Del Sol check engine light?
Old Jul 23, 2004 | 05:14 PM
01ACCORD's Avatar
01ACCORD
Default '93 Del Sol check engine light?
My cousin just called and said his '93 Del Sol is turning on the Check engine light intermittently. Since it probably doesn't have the OBDII connector, is there a way to get the code? Also, does anyone have a link to a list of codes for the '93?
Thanks.
Old Jul 23, 2004 | 07:10 PM
spoony74's Avatar
spoony74
Turn your car off. Look under your dash in the passenger footwell, and you'll find a single plug in a green boot. You don't even have to pull back the carpet to find it. Jump the two terminals with a paperclip or some other metal thing. Flip on the ignition, but not the engine. The CEL (check engine light) will start flashing, morse code style (dash/dot). Count the number of long flashes and short flashes. The code will repeat. In my case I got 4 long flashes and 1 short flash. Hence code 41.
A website with all codes for honda
http://www.geocities.com/honda_club_egypt/ecu.htm
Code Accord Civic CRX Prelude Error
1 85-98 86-98 85-91 85-98 Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
2 85-89 86-87 85-87 NA Oxygen Sensor "B"
3 85-98 86-98 85-91 85-98 MAP Sensor (Manifold Absolute Pressure)
4 90-98 88-98 88-91 85-98 CKP Sensor (Crankshaft Position Sensor)
5 85-98* 86-98 85-91 85-98 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
* exc 94-95
6 85-98 86-98 85-91 85-98 ECT Sensor (Engine Coolant Temperature)
7 85-98 86-98 85-91 85-98 TP Sensor (Throttle Position)
8 85-98 86-98 85-91 85-98 TDC Sensor (Top Dead Center)
9* 85-98** 86-98 85-91 85-98 CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10 85-98 86-98 85-91 85-98 IAT Sensor (Intake Air Temperature)
12 85-98 86-98* 85-91* 85-98 EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13 85-98 86-98 85-91 85-98 BARO Sensor (Atmospheric Pressure)
14 88-98 88-98 88-91 88-98 IAC Valve (Idle Air Control)
15 90-95 88-95 88-91 88-95 Ignition Output Signal
missing or defective ignition output signal
16 90-95 88-95 88-91 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
17 88-98 88-98 88-91 88-98 VSS (Vehicle Speed Sensor)
19 NA 88-95 88-91 NA Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20 90-98 88-98 88-91 92-98 Electrical Load Detector
21* 94-98** 92-95 NA 93-95 VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
22* 94-98 92-98 NA 92-98 VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23 98* 96-98 NA 92-98 KS (Knock Sensor)
* not a valid code if V-6 engine
30 90-98* NA NA 92-98* Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
* not a valid code for 1996
31 90-95 NA NA 92-95 Automatic Transmission Signal "B"
41 90-98 92-98 NA 90-98 Primary Oxygen Sensor - Heater
circuit malfunction
43 90-95 92-95 NA 90-95 Fuel Supply System
defective or malfunctioning fuel supply system
45 96-98 96-98 NA 96-98 System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48 98 92-98 NA NA LAF Sensor (Lean Air Fuel)
54 96 96-98 NA NA CKF Sensor (Crankshaft Speed Fluctuation)
58 98* NA NA NA TDC Sensor 2 (Top Dead Center)
* with V-6 engine only
61 96-98 96-98 NA 96-98 Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63 96-98 96-98 NA 96-98 Oxygen Sensor, Heated - Sensor 2 (Secondary)
65 96-98 96-98 NA 96-98 Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67 96-98 96-98 NA 96-98 Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70 96-98 96-98 NA 96-98 Automatic Transmission
malfunction with the automatic transmission controls
71 96-98 96-98 NA 96-98 Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72 96-98 96-98 NA 96-98 Cylinder 2 Misfire or a Random Misfire
73 96-98 96-98 NA 96-98 Cylinder 3 Misfire or a Random Misfire
74 96-98 96-98 NA 96-98 Cylinder 4 Misfire or a Random Misfire
75 98* NA NA NA Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
76 98* NA NA NA Cylinder 6 Misfire or a Random Misfire
80 96-98 96-98 NA 96-98 Exhaust Gas Recirculation
insufficient flow detected
86 96-98 96-98 NA 96-98 ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90 97-98 96-98 NA 97-98 Evaporative Emission Control System
leak detected in the fuel tank area
91 96-98 96-98 NA 97-98 Fuel Tank Pressure Sensor
low input
92 96-98 96-98 NA 96-98 Evaporative Emission Control System
insufficient purge flow
Old Jul 23, 2004 | 07:17 PM
01ACCORD's Avatar
01ACCORD
Hot Damn! Perfect. Glad I have OBDII :-)
But hey, it's better than nothing for sure!
