Compression #'s for a B16?
Old Jul 21, 2004 | 10:18 AM
prodigalson's Avatar
prodigalson
Default Compression #'s for a B16?
I'm looking at purchasing a Del Sol VTEC (115K miles) and I am going to get the compression checked. What is the normal compression for a healthy B16 engine?
Thanks,
Old Jul 21, 2004 | 01:15 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
above 200 i believe. The B16 has a 10.6:1 compression ratio.
Old Jul 21, 2004 | 04:33 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Thats 10.2, actually... and 10.4 for the japanese one. For a USDM motor with that many miles, I'd be satisfied with anything over 185psi or so, as long as it was consistent cylinder to cylinder.
Old Jul 21, 2004 | 05:04 PM
Kai's Avatar
Kai
Rotorphile.
Yeah, I'd say even numbers at 180psi or better.
Old Jul 22, 2004 | 05:00 AM
prodigalson
Great. Thanks for the info...
Old Jul 22, 2004 | 05:46 AM
s1ngle's Avatar
s1ngle
doh! sorry
well my car is like 9.4:1, and i get 190's across the board...
Old Jul 22, 2004 | 06:01 AM
shifty35's Avatar
shifty35
I got ~210 psi on all 4 cylinders on my D16Z6, 144k mi.
Old Jul 22, 2004 | 06:36 AM
s1ngle's Avatar
s1ngle
whats the comp. ratio on a Z6? isnt it slightly higher than the Y8? like maybe 9.6:1 or something?
Old Jul 22, 2004 | 12:53 PM
white_n_slow
it's my D in a B
9.2:1, actually... there may be some other factor that makes d-series motors register higher compression, does seem odd :thinking:
Old Jul 22, 2004 | 01:37 PM
s1ngle's Avatar
s1ngle
he's probably got some carbon build up. My manual says the best compression you should expect is 185.
Gosh, i'm getting whupped on all these compression ratios. Thanks again white n slow.
