94 civic- DS window problem
Old Jul 17, 2004 | 06:40 AM
Jody's Avatar
Jody
Default 94 civic- DS window problem
I have a 94 civic and the driverside window likes to fall out of track. I have removed the door panel and tightend up the bolts that hold the mechanism in place but for some reason the front side of it has a lot of play in it which basically allows the window to become unlevel and causes it to fall out of the track. Does anyone know of a fix for this? or if its a common problem with this year of civic?
thanks
Old Jul 23, 2004 | 11:59 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
replace the window track guide rubber peice (I don't remember the name for it)
you can try slotting the adjusters a little more but it's a temp fix.
Old Jul 23, 2004 | 02:01 PM
monicle's Avatar
monicle
Repo.Jackmoves.Com
there are actually 6 bolts that hold the entire regulator in place. 4 which are right near the crank and 2 more near the rear of the door. these 2 bolts are actually used to adjust the levelness of the window. I would look at these two to make sure they havent moved and also make sure that they are secure. other than that you might replace that rubber or more simpley lube it up swith some silicone lube
Old Jul 23, 2004 | 06:26 PM
saga's Avatar
saga
broke college kid
My PS window was like this and I went to a local auto glass place to have them take a look at it. The regulator was bent so they banged the shit strait and reglued the clips into place and fixed me right up. All for $50. Take out the window and the regulator and check it to see if it's alright. Also, it could just be the rubber stuff (I also don't know the name of that piece) that guides the window although if it's falling out completely it sounds like something with the regulator.
