Need help asap - Electrical gremlins?
Old Jul 14, 2004 | 04:35 PM
92lx
Guest
Posts: n/a
Default Need help asap - Electrical gremlins?
Hi guys,
having some trouble, I am putting in some new headlights and I was doing some wiring off of the turn signal lights. Anyhow, after hooking up what I thought were ground and positive - the corner lights went out, and do not have power going to them now.
Okay, so the headlights still work, the turn signals work, but not the running light element of the turn signal bulb.
Is there a fuse that controls just that? because I'm having a hard time finding it if there is.....I checked (at least I think it was all) all the fuses under the drivers' side dash and under the hood under the fuse box cover. All of them were checked with a meter and visually, and seemed to check out.
Any ideas on how I can fix this problem? I've been trying to figure this out for about 2 hours now. Thanks!
- Nathan
Old Jul 14, 2004 | 04:44 PM
92lx
Guest
Posts: n/a
also does anyone know what wire color does what in that set of wires, there are 3, one is red/black, one black/???? and the other green/yellow I believe.
I think I found the green/yellow to be positive, but only when turn signals are active, the others are???
- Nathan
Old Jul 14, 2004 | 07:21 PM
92lx
Guest
Posts: n/a
ttt
Old Jul 15, 2004 | 05:26 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
yes there should be a fuse for it. reference the little plastic card on the fuse box door under your dash. also have you checked the fillament on the bulb itself?
Old Jul 15, 2004 | 09:47 AM
92lx
Guest
Posts: n/a
I have, it's fine, but there is no power (for sure)...so it's deffinately not in the bulb. I looked at a fuse diagram, and there were no listed fuses for that, for the headlights sure, but they work, and for the turn signals there is a relay, but unless the relay got messed up somehow?
- Nathan
