motor problem
Old Jul 11, 2004 | 06:30 PM
kosmichonda's Avatar
kosmichonda
Default motor problem
well im on motor number 2. the first motor went in real smooth and i got it started on the first try. then started to put the coolent in and it was never filling up so i pulled the dip stick out and all the water and coolent shot out like a fountain. so i pulled that motor out.(and yes the head gasket was on right). the next day i went and bought a d16z6 motor. i had to put the clutch and tranny on this motor. this motor went in smooth too. i didnt have the distruter hooked up yet but i wanted to see if it would turn over, and it didnt. i then pulled the tranny to see if something was not on right. it all looked good so i put the tranny back on. tryed to start it again and got nothin.
so my qustion is does anyone no what is wrong. every time i turn the key it sounds the starter goes put the fly wheel is stoping it. i checked mt belts to see if they were too tight and there not. it turns over a little then stops then truns alittle then stops then it just gives up. then i felt the starter and it was very warm. any ideas??
Old Jul 11, 2004 | 06:34 PM
MPerson's Avatar
MPerson
Try to manually crank it with the crank pulley bolt. If it moves around and around it could be the starter. If it doesn't move, then it's something internal or the flywheel. Did you try and crank it when you had the tranny off?
Old Jul 11, 2004 | 06:37 PM
Kai's Avatar
Kai
Rotorphile.
Sounds like a frozen engine. If it doesn't turn by hand (which should be very easy,) take out the spark plugs and look in each cylinder with a flashlight. If you see water or rust, you're out of luck.
Old Jul 11, 2004 | 06:40 PM
kosmichonda
yes i have cranked it when the tranny was off and when it was on. when i pull it tords the front bumper it wont move but when i push tords it back it moves after a click noise then i can move it both ways. i think the click noise is the starter going back in cause i think it was out that is why it wouldnt move tordes the front bumper.
Old Jul 11, 2004 | 06:41 PM
bambbrose's Avatar
bambbrose
Might sound stupid but the battery is in good shape right?
Old Jul 11, 2004 | 06:47 PM
kosmichonda
yea i took it out and it started my friends 240sx. so i think so
Old Jul 13, 2004 | 01:11 PM
kosmichonda
ok well i think im just going to give up and have some auto place fix it for me.
