VTEC question
Old Jul 8, 2004 | 07:44 AM
Lambert's Avatar
Lambert
H22 EG6
Default VTEC question
I was wandering how to find out if I have a VTEC. If I don't, is there a way I can make my motor have a VTEC?
I have a D16Z6 motor on my car.
Thanks,
Lambert
Old Jul 8, 2004 | 08:11 AM
WHITEPEARL ACC's Avatar
WHITEPEARL ACC
D16Z6 is a EX/SI 92-95 engine that has VTEC....
so answer is yes, u have it...
Old Jul 8, 2004 | 10:51 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Correct, the D16Z6 is a VTEC motor.
Old Jul 8, 2004 | 04:12 PM
Lambert's Avatar
Lambert
H22 EG6
It does not say VTEC on my valve cover or any where on the motor. Are you sure my car has VTEC, if I do is there any where I can check?
Thanks,
Lambert
Old Jul 8, 2004 | 05:17 PM
westcoaststyle
If it has D16Z6 stamped on the block it IS a VTEC motor. Just because it's not on the valve cover doesn't mean anything. Here's the specs: http://www.clubcivic.com/board/specs.php. Just search for D16Z6 and you'll see.
Old Jul 8, 2004 | 05:33 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
i thought the d16z6 valve cover DID have VTEC stamped on it???!?!?!
Old Jul 8, 2004 | 05:57 PM
Kai's Avatar
Kai
Rotorphile.
Only about 1/3 of them do have it marked on the cover.
Old Jul 8, 2004 | 06:12 PM
honura's Avatar
honura
Seni
Yep Honda must have been doing bad those years cause they stopped using those value covers. Dahm I hate when car companys do that!
Old Jul 8, 2004 | 06:17 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
you should be able to FEEL the vtec evan on the sohc engine.
Old Jul 8, 2004 | 07:07 PM
s1ngle's Avatar
s1ngle
yeah, its like bwaaaaaAAAAAAA!!! and it shoves you back in your seat like nawwws!
