i need help!! rsx rear seats in ek coupe?
Old Jul 1, 2004 | 09:39 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Originally Posted by lkailburn
should be 3 of the 4 bolts line right up. i'll just have to cut/weld/fab somethin up for the 4th bolt.
i actually found this picture the other day. i forgot where tho:
EDIT: found it again. hes a member on jdmc. i pm'ed him so hopefully he can help me get the fronts in
If 3 of the 4 bolts line up it should work fine, GSR seats are the same way in EJs. Just use the notch trick for the last bolt or swap the rail for the one that doesn't both line up
Old Jul 1, 2004 | 11:03 AM
lkailburn's Avatar
lkailburn
college kid
whats the "notch trick" ?
_luke
Old Jul 1, 2004 | 11:05 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
_luke
Well if i remember correctly you use a bolt and some big washers and screw the bolt into the hole so the mounting bracket for the seat is wedged under the washers to hold it down.
Old Jul 1, 2004 | 11:38 AM
lkailburn's Avatar
lkailburn
college kid
aight well when i pick up the seats i'll see whats up
Old Jul 1, 2004 | 03:33 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
wait... so THREE OF THE FOUR BOLTS BOLT RIGHT UP!!!
thats it im buying a set!
Old Jul 1, 2004 | 03:38 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
i found this for you about the rear seats
http://www.honda-tech.com/zerothread?id=847565
im definately getting rsx seats now !!
Old Jul 1, 2004 | 05:52 PM
lkailburn's Avatar
lkailburn
college kid
ok maybe its just me but the bolts deffinitly do not line up. i can't even get the second one in....
maybe its just cuz its so freakin hot outside, and its dark but idk... deffinitly don't line up..
and the seat belt sensor doesnt fit the plug on the rsx seat.. just a side note
_luke
Old Jul 1, 2004 | 06:44 PM
lkailburn's Avatar
lkailburn
college kid
anyone have personal experience with getting the front seats in?
Old Jul 1, 2004 | 09:36 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
_luke
Make sure the rails/sliders are in the correct positions i.e. one isn't way forward and one way back or else it'll never line up. If people have done it before they should fit unless you have a different generation civic than the guys that have done it before.
Old Jul 1, 2004 | 09:45 PM
Kai's Avatar
Kai
Rotorphile.
I have yet to figure out why Honda guys are so intent on swapping stock seats. Aren't the RSX seats hella tall? :thinking:
