question about a rear disk swap
Old Jun 23, 2004 | 09:37 AM
Nelson's Avatar
Nelson
Administrator
Let's stay on topic
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jun 23, 2004 | 10:29 AM
lkailburn's Avatar
lkailburn
college kid
damn, off topic in my own thread even hahahah. well all of my questions were answered so i'm all set.
thanks again
Luke
Old Jun 23, 2004 | 09:20 PM
PHiZ's Avatar
PHiZ
BOOST GOD
1991 EG9? Is that fifth gen, or a fourth gen?
WestCoast, the 6th gen Prop Valves don't have 4040 stamped on them. I have two here, if you wanna compare numbers.
-PHiZ
Old Jun 24, 2004 | 04:52 AM
lkailburn's Avatar
lkailburn
college kid
91 would be 4th gen
phiz- from what i learned here, i think only the si prop valve is 4040. others are 8020
Old Jun 24, 2004 | 07:44 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Originally Posted by lkailburn
91 would be 4th gen
hehe, which Si ???
the 4040 stamp is a 60/40 front bias. Drum setups are a 80/20 front bias.
I think that's where your number comes from.
6th gen civics, the prop valves aren't stamped with 4040, even if it is an Si.
From what I understand.
-PHiZ
Old Jun 24, 2004 | 07:45 AM
Outxider's Avatar
Outxider
X-Motoring
in japan the years for the generations r off. the jdm 91 eg9 would be here usdm 92 civic sedan.
Old Jun 24, 2004 | 10:19 PM
Is300man's Avatar
Is300man
I think the 99-00 civic si prop valves are the same as the 96-00 civic hatches prop valve. The coupe and the sedens are the ones that are different from the SI
Old Jun 25, 2004 | 02:39 PM
dantastic's Avatar
dantastic
cx power!
Originally Posted by Outxider
hmm if u dont upgrade the prop valve, the pedal engagement would be later then it would. trust me, get the prop, my friend ran a rear disc on his 97 ex without a prop valve and his brake pedal was sloppy until he slap a 99si 40/40 on it, made one hell of a difference. :thumbup:
the problem was probably poorly bled brakes. i had the stock prop valve in, then switched to a 30/40 (4 wheel disc, non-abs). it didnt make any diff in pedal travel.
