BOV noise
Old Jun 8, 2004 | 07:28 PM
etrauty's Avatar
etrauty
Default BOV noise
What would cause the BOV to make a fluttering noise. Also I have a drag 3 turbo kit on my 2000 civic ex. What RPM should it start to boost??
Old Jun 8, 2004 | 07:30 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
loosing the screw up will do that.
my buddy with a WRX wanted a fluttering sound, so he loosened to the screw on the valve or somethin...
Old Jun 8, 2004 | 08:06 PM
honura's Avatar
honura
Seni
I think 2500 -3000 rpm. But im not 100% sure on that. The past 2 civics I have seen have started at around that range.
Old Jun 8, 2004 | 08:15 PM
etrauty's Avatar
etrauty
you now of any reason why its not hitting till about vtec. 5500??
Old Jun 8, 2004 | 08:16 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Whats not hitting?
Old Jun 8, 2004 | 08:18 PM
etrauty's Avatar
etrauty
boost,bov, vtec anything actually
Old Jun 8, 2004 | 08:19 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Check for boost leaks.
Old Jun 8, 2004 | 08:22 PM
etrauty's Avatar
etrauty
is there a place thats prone for a leak, or any easy way to check, or the old soap and water?
Old Jun 8, 2004 | 08:24 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Check the manifold/turbo flange. Your turbo might be hitting the block and not sealing enough. Also check all couplers.
Old Jun 8, 2004 | 08:27 PM
etrauty's Avatar
etrauty
will I actually be able to find out at idle. I'm don't know but I thought the car had to be moving for the turbo to spool enought to check for leaks, please correct me if i'm wrong
