Wiring to ECU-need to know how to connect it
Old May 10, 2004 | 12:37 PM
novabound2003's Avatar
novabound2003
Default Wiring to ECU-need to know how to connect it
So , how does one go about connecting the wires for Vtec etc to the ECU? soldering? getting the pin connectors? or just jamming it right into the ecu (duh).
Old May 10, 2004 | 01:41 PM
honura's Avatar
honura
Seni
Well it depends. What I would do is get the pins at the dealer ( you will need 2) and thats it.
Old May 11, 2004 | 06:48 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
You can also stop by your local junk yard and just pull the ECU plug off and hack a few pins out of it to use. When I first did my swap, all I did was twist the wire up, shove in the back of the plug till it started to stick out the other side than plug the plug back in. Worked fine for about a year. I was a friends local shop who buys wrecked cars and strips them and I managed to grab a few pins with a small amount of wire attached (they just cut up an entire junk ECU harness) and soldered and heat shrink wrapped the new connections. Probably better that way, but both worked.
Old May 11, 2004 | 09:00 AM
supermac88's Avatar
supermac88
not OG but Old School
I jammed my twisted wires through works fine. To hell with it I am lazy and refer to african american engineering (it's a joke relax.)
Old May 11, 2004 | 10:08 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I went to the dealership and got the pins I needed. h:
Old May 11, 2004 | 10:17 AM
Civic2Scooby's Avatar
Civic2Scooby
I went to the junkyard and cut the harness plug off, then opened her up and pulled the pins I needed....do it the right way...:goodjob:
LT
2
Oct 5, 2004 07:07 PM
Scia
92+ Civic/EL & Del Sol
2
Aug 18, 2003 08:41 PM
ambition
Aug 7, 2003 10:48 AM
Sleeper00
Accord
2
Apr 24, 2003 09:24 AM
Solid Alibye
Engine Swaps, Tech & Tuning
Jun 27, 2002 11:55 AM
