jdm eg9 headlight question
Lexus Tech y0!!
i dont know if i was supposed to put this in the app/cos forum but here goes. i will be getting the jdm headlights and corners after i sell my ricey
projectors and i want to know something. is the installation of the headlights any different than the stock ones, how would i wire the courtesy lights? mods feel free to move to the app/cos forum and i apologize for doing this. any info on this would help greatly. thanks!
I am tehguy... OH YEAH!!
I think Josh (westcoast) has teh lights from JDM land. Not sure who else has them on here; I think I saw a hatch on here with them... or was it a coupe :thinking:
Install is the same. Most people wire the city lights into the constant wire (red I think) of the corner lights, and cut the constant from going to the corners. This way they come on instead of your parking lights, and your corners only flash.
everything is the same installation wise.
if you want to wire up the courtesy lights ...use the constant wire from the corner lamps.
Still here... sorta...
good post in here I think.
They install exactly the same. You can do what you want with the city lights.
the way I did it
cut the wire that provides power to the dim filiment of your corners (parking lights)
route that wire to your city light and run the other city light wire to a ground
This will make it so that the city lights illuminate when you turn on your parking lights and your corners only light up when you turn on your signal
the way I will eventually do it
run the power wires from my parking lights/headlights switch to an on-off-on switch
one 'on' goes to the parking lights, the other 'on' to the city lights. This will allow you to switch from parking lights to city lights at any time.
In addition, I will run a relay between the city light power wires with an actuation wire from the power wire going to the headlights. This will make it so that if I have the 'on' set to have the city lights on, when I turn on my headlights the city lights will no longer be on because they won't be visible anyway. h:
Long winded I know, but... there you have it.
the way I did it
inlinefour has em. they r a common socket. can be found on 5g civics on the rear tail lights as the side light. 3g integra front parking lights. 5g accord front corner lights.
Originally Posted by HatchVX
NOt to thread jack, but do u know where i can get some EG city light sockets??
