Disc Conversion in EK civic
Old Apr 25, 2004 | 09:32 AM
92eg6's Avatar
92eg6
99 CG3 Owner
Default Disc Conversion in EK civic
Will a 95 integra gsr rear disc setup fit on a 96 ek civic hatch? if it does and i am wrong how diffrent then bolting up to a EG?
Old Apr 25, 2004 | 10:02 AM
Outxider's Avatar
Outxider
X-Motoring
yes it will. u will need the trailing arms complete. im not entire sure if u can use the teggy ebrake cables, but u will reuse ur stock lca cuz the teggy ones will not fit. u can always go aftermarket on those as well. at the same time, i recommend that u get the 99-00 Si master cylinder and prop valve.
Old Apr 25, 2004 | 10:04 AM
randomtask77's Avatar
randomtask77
Wanderer
Yes it'll fit. The only thing that you'll need differently in your car is the parking brake cables (you're gonna need the longer ones and not the ones you have now) and change the brake master cylinder and the proportioning valve (if you want to get the full braking potential of the new system).
Do a search if you need more thorough info. This has been covered quite a few times.
Old Apr 26, 2004 | 04:55 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
the need for longer ebrake cables is a myth. the integra ones will work however you will have to zip tie the passenger side up instead of it attaching with the holding bracket. If youre one of those people who has to have everything spick and span then you may want si cables and everything will bolt up like stock.
metalman
May 2, 2004 07:58 PM
ghostdriver
92+ Civic/EL & Del Sol
3
Mar 8, 2004 11:51 PM
Stanley
May 17, 2003 03:35 PM
jaje
News & Rumors Archives
17
Jun 27, 2002 03:16 AM
