thrown rod bearing
Old May 5, 2004 | 03:33 PM
akuma's Avatar
akuma
ok i took it to honda to try and get them to fix the rod bearing but they said it would cost me between 3300 to 4100 to fix depending on parts that may need to be replaced like the clutch, drive belts, oil, coolant and so on. Is this bs or is it really that bad
Old May 5, 2004 | 06:37 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If you're willing to do a swap, that means you're willing to do some work yourself. Yank the motor, have the bearing journals redone, and get the crank polished. Get some over sized bearings, new rings, and a head gasket, and you're back on the road. Might want to do an itr oil pump while it's out, but not a NEED. Cost of bearings, rings, fluids, etc should be less than 200, and the machine work shouldn't be too bad either.
Old May 5, 2004 | 07:11 PM
StErN's Avatar
StErN
HAN Approved Vendor
Take the block to a machine shop, it will be much cheaper. I'm in the process of getting my gsr rebuilt with some Itr over sized pistons and all new rod and main bearings, plus thrust washers and its only going to be about $250, and thats with the machine shop supplying the pistons rings and bearings. :thumbup:
Old May 6, 2004 | 11:58 AM
Jafro's Avatar
Jafro
I'm made of meat!
Hahah!!! No. You just took your car to a dealer. Whenever you partake in dealership service, you should walk in the door grabbing your ankles, and bring plenty of lube. They don't use any, so you'll want to be prepared. Dealerships charge insane amounts of money for major R&R work. That's a given.
akuma
Engine Swaps, Tech & Tuning
Apr 21, 2004 03:58 PM
ragerized
92+ Civic/EL & Del Sol
7
Mar 29, 2004 03:36 PM
lsvteg
2
Aug 10, 2002 08:53 PM
