annoying stutter....
Old Apr 21, 2004 | 08:09 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Default annoying stutter....
I'm stumped on this one...
I've got a b18b in my 95 si hatch.
It will stutter when I floor it through the gears. It will stutter off the line in 1st (not going anywhere) and then BAM it'll pull like a mofo. If I'm cruising at about 40-45 in 5th and floor it, it just stutters til I let part way off the gas.
I've tried 2 differnt throttle position sensors. I've replace the cap, rotor, wires. The mechanical timing (cam gears and crank) are perfectly aligned. The ignition timing is perfect, and I've tried it advanced and retarded. No codes are being thrown.
If I let it idle, it will stutter ever minute or two. If I hold the throttle with the car sitting still, and keep a constant rpm, it will fluctuate about 25 rpms up and down. That doesn't seem unresonable, but still might be a sign of what's going on.
I'm just stumped on this. It will stutter to the point of not wanting to move at times, and this is my daily driver. The motor has been in the car about a month, and ran great for about 2 weeks... Now I'm just frustrated...
Old Apr 21, 2004 | 08:41 PM
SonicGSR98's Avatar
SonicGSR98
Shadow Lurker
I've been kinda helping James with this problem, and frankly, it has me stumped as well, everything inside the Distributor is in order and all is well, other than the stutter?!?! WEll, maybe time to lok into replacing the Ignitor?
Old Apr 21, 2004 | 08:58 PM
B18_Civic's Avatar
B18_Civic
does it do it at any rpm?
Old Apr 21, 2004 | 09:00 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
it's completely random...
Old Apr 21, 2004 | 09:03 PM
B18_Civic's Avatar
B18_Civic
do you have you been messing with the fuel pressure?
Old Apr 21, 2004 | 09:32 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I haven't touched the fuel pressue. The motor is completely stock other than an intake for now... I wanted to get it stable before messing with anything...
Old Apr 21, 2004 | 09:58 PM
Hondaman's Avatar
Hondaman
Black Pearl
I would get the injectors tested and cleaned. It sounds like you have a bad/clogged injector.
Old Apr 22, 2004 | 08:10 AM
Spood's Avatar
Spood
Sucka
Is there anyway the donor car's front-end collision may have contributed? Knocked something loose somehow? :dunno:
Old Apr 22, 2004 | 08:29 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
its the o2 sensor... my car had the same exact problems, completely random stutters, & wasnt even throwing any codes.
Old Apr 22, 2004 | 03:07 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
spood: the dizzy was replaced with one from another teg because the intake got pushed into the cap and broke it.
jeterkm02: I'll replace that this weekend. I have one sitting on a manifold at my buddy's house an hour north of here!
Any other ideas on what it could be?
