Installing XENON WHITE light bulbs...
I just bought some OptX bulbs
http://www.optxbystreetglow.com/hidbulbs.htm
Anyway, I was woundering on how to toake out the old ones,
I see it in there i just dont know how to take it out,
am i doing something wrong i tryed pulling it out,twisting it...
thanks for the help.
What kinda car,trim? That would help. It's a pretty straight foward job. If it's an h4 (9004) then just twist the plastic off, Pull out te bulb, and replace it. If it's an H3 Then take the metal rod of the holds the bulb in and take the bulb out and replace it. Hope that helps.
cx power!
[QUOTE=dantastic]...before you install the new bulb, swab it with denatured alcohol so it wont expode, QUOTE]
I have never put alcohol on any of my bulbs. Does it make it last longer or does it keep the aftermarket high watt bulbs from exploding??? Some info on that...
cx power!
[QUOTE=98WhtCivicEx]
oops sorry for being vague. you skin has natural oils on it. if they get on a halogen bulb, the high heat can cause it to crack the bulb. swabbing it with alcohol will remove the oil. even if you never touched the bulbs, someone else may have when handling the bulbs, so it always a good idea to clean them
Ohhhh...gotcha...so is this just normal rubbing alcohol you would use on cuts or something different?
I love all the smart people on HAN!! Its great!!
cx power!
