Timing belt change?
Old Apr 4, 2004 | 07:38 AM
crack's Avatar
crack
Default Timing belt change?
I have a 99 ek. I am wondering the spec as to when i should change the timing belt? I have been told 90k. But I have also been told 60k. Which is it?
Also, if it is 60k i am doing it on tuesday... can someone point me somewhere or give me some advice on doing this?
Thanks in advance...
Old Apr 4, 2004 | 07:48 AM
Kestrel's Avatar
Kestrel
Push to shock!
It's in the manual in the back under servicing requirements. I think Honda says about 80k, but I could be wrong.
Old Apr 4, 2004 | 09:09 AM
m735is's Avatar
m735is
My 92 Civic is 60K (lasted 245,000 before I changed it out of fear), my wifes 00 CR-V says 90 K(only has 70,000). The belt is pretty cheap, I would do the water pump at the same time. I use Haynes manuals and take my time, no problems.
Old Apr 4, 2004 | 09:24 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
I believe the Honda manual has 2 specs, one for normal use and one for extreme use. The normal is 90k and the extreme (might be the wrong word) is 60k. Extreme is lots of hard driving and extreme temps and such. I drove my '98 EX pretty hard and it just turned over 101,000 miles on the stock belt and water pump. I have an OE replacement for both along with a new clutch I'm probably going install on wednesday.
Old Apr 4, 2004 | 10:23 AM
Kai's Avatar
Kai
Rotorphile.
I'm actually like to do it every 50-60k.
Old Apr 4, 2004 | 11:56 AM
bambbrose's Avatar
bambbrose
this man is correct.. 60k for extreme climates such as extreme hot or cold or very hard driving.. 90k for climates that are normal.. extreme hot or cold is over 100 degrees or less than 0 on a yearly basis or something like that
Old Apr 5, 2004 | 11:34 AM
mjej's Avatar
mjej
I just got ALL my belts changed and im at 99,000 the recommended is between 90 - 110,000 miles and water pump has to go. My water pump was allmost dead at 96,000
Old Apr 5, 2004 | 11:36 AM
mjej's Avatar
mjej
jesus do you run your car that hard? i mean do you do it yourself? that's really early.
Old Apr 5, 2004 | 03:27 PM
Kai's Avatar
Kai
Rotorphile.
It is incredibly easy to change the T-belt on an '87 Civic, that's what my last one was. It was the only car I've ever had long enough to change the belt though.
I'd rather spend a couple hours and a few bucks changing the t-belt then a couple days and a few more bucks changing the engine.
Now that I've graduated to the Wankel Rotary, I don't have to worry about timing belts anymore.
petrv
Prelude
10
Mar 17, 2004 07:50 PM
ChrisGSR
Engine Swaps, Tech & Tuning
2
Mar 24, 2003 03:43 PM
davekaro
92+ Civic/EL & Del Sol
7
Jan 7, 2003 12:00 PM
