need help with lowering
Old Aug 4, 2002 | 09:34 PM
stock99's Avatar
stock99
Default need help with lowering
I waant to lower my 99 civic ex coupe with some springs, I want about a 1 inch drop. What springs are good? I was lookin at eibach pro kits. I will be on stock struts, btw. Also, will my camber and toe in be fixed with an alighnment? Also, one last thing, where are some good places to buy springs online? thanks.
Old Aug 4, 2002 | 10:26 PM
randomtask77's Avatar
randomtask77
Wanderer
www.groupbuycenter.com
Old Aug 4, 2002 | 10:29 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Your camber shoulnt be too much of a problem with the 1 inch drop, but toe in/out might get a little out of spec after the install. An alignment will fix any of those problems.
Old Aug 5, 2002 | 02:34 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
You will need ot get an alignment whenever you change the height of your car. You get toe out (I think) when you drop and toe in when you raise the car. Toe can affect how quickly your tires wear out too.
Most people suggest a camber kit with a 2" or more drop.
Autocross Help Page
Old Aug 5, 2002 | 04:24 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
before you do it make someone in town sign a paper saying theyll align your ****ing car if you drop it. im gonna shat myself if someone doesnt align my car pretty soon.
Old Aug 5, 2002 | 04:25 AM
Fujiwara Takumi
It's my first day.
and with good reason, ive been on my drop without camber correction for around 2 mos and there is noticeable wear on my tires right now. dropping the car doesn't cause any serious toe problems until you correct the camber, when you do that, toe out becomes serious. mine is so bad right now both tires squeel as i drive straight.
Old Aug 5, 2002 | 04:35 AM
white lightnin's Avatar
white lightnin
I had to call a few places til goodyear did mine, and overtightened my lugs warping my brand new rotors. I would recomend more than 1". You wont even be able to really tell with that much of a drop. Try an eibach prokit. Bout an inch and a half drop. Not too low but enough to fill the gap.
Old Aug 5, 2002 | 05:56 AM
Fujiwara Takumi
It's my first day.
im at about 3" i think, i have about 1/8" - 1/4" fender gap.
I got my front alignment done today, they said i needed a rear camber kit too or i was going to tear my wheels off. (you can visibly see the toe is off). it was about $60 from a local guy with the right tools who knew what he was doing. **** goodyear.
Old Aug 5, 2002 | 06:19 AM
Duff Man's Avatar
Duff Man
don't need a camber kit with less then a 1.75in drop
Old Aug 5, 2002 | 06:20 AM
stock99's Avatar
stock99
anybody know of any good deals besides the group buy goin on right now?
