Fuggin FRont Bumper
Old Aug 4, 2002 | 11:18 AM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Default Fuggin FRont Bumper
DAMMIT! I can't get my front bumper off. I got all of the bolts off expect for the ones under neither the hood. They are rusted into place. I already tired a **** load of liquid wrench but that didn't do anytihng.
Old Aug 4, 2002 | 12:41 PM
agent87's Avatar
agent87
Need zzzzz's
Are you referring to the 5 screws on the top of the bumper cover?
Old Aug 4, 2002 | 12:44 PM
The G2 Racer
Want Boost!
Yes I can't get them to come out. Should jsut drill them out?
Old Aug 4, 2002 | 12:59 PM
j.fuggi's Avatar
j.fuggi
g-g-g G-UNIT
do they move? or are they just turning in place?
Old Aug 4, 2002 | 02:01 PM
The G2 Racer
Want Boost!
They aren't turning period.
Old Aug 4, 2002 | 03:24 PM
str8edgexx's Avatar
str8edgexx
Drilling is your last resort. Try hitting them with a hammer to try to bust them loose. Sometimes if you knock them a few times, it'll free them up. If that doesn't work, they have this tool that you put into the screw head (it has either a philips or flat head attachment) and you hit it with a hammer, and as you hit it, it turns. That sometimes helps for getting out really stuck screws. You may also try getting a variable speed drill with a reverse setting, set it to its highest torque setting, push down on it as hard as you can into the screw, and then push the trigger so it spins a SLOWLY as possible. If you do it to fast, you'll strip the life out of it. Try those three things if you can get your hands on the right tools. If none of them work, then use drilling as your last resort.
Old Aug 4, 2002 | 06:01 PM
randomtask77's Avatar
randomtask77
Wanderer
I hope that the screw heads weren't stripped. Make sure that you have the right sized philips head screwdriver and the job should be that much easier.
Old Aug 4, 2002 | 07:36 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
uh, I just use pliers... grab em and turn...
LSBrother06
Jan 10, 2005 05:27 PM
ElectronBlueGSR
Feb 24, 2003 12:27 AM
VoLTRoNx916
Dec 9, 2002 11:40 PM
Jeice
92+ Civic/EL & Del Sol
13
Jun 27, 2002 12:56 AM
