more on my turbo problems
Old Mar 29, 2004 | 01:10 PM
supermac88's Avatar
supermac88
not OG but Old School
Default more on my turbo problems
I am throwing a code 3 which is; Open or short in MAP sensor circuit, defective MAP sesnor. Now if it was reading boost at the map wouldn't it throw a code 5. So is my map bad or what?
Old Mar 29, 2004 | 01:25 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I have another map I can send you so you can test it out if you'd like?
I don't remember how much boost you said you were running but the stock 2BAR map sensor is only good up to 11.3 psi. Just so you know.
Old Mar 29, 2004 | 01:32 PM
supermac88's Avatar
supermac88
I am running stock boost 5.5 lbs
Old Mar 30, 2004 | 03:19 AM
Kai's Avatar
Kai
Rotorphile.
Civic... stock boost... :chuckles:
Old Mar 30, 2004 | 06:53 AM
ragerized's Avatar
ragerized
dc4 ownerages
didnt ya know? hondas offering the turbo package on all the new civics.
Old Mar 30, 2004 | 08:02 AM
Civic2Scooby's Avatar
Civic2Scooby
I do believe he ment stock psi for the specific internal waste gate on his 15g..:fawk:
Old Mar 30, 2004 | 08:19 AM
supermac88's Avatar
supermac88
:werd: I am running 5.5 lbs which is what the internal wastegate on the 15g is set to at the manufacturer.
Old Mar 31, 2004 | 09:17 AM
supermac88's Avatar
supermac88
bump god dang where are all the turbo people at I have threads up in 2 other forums with replys just like these what's really going on?
Old Mar 31, 2004 | 09:42 AM
Kai's Avatar
Kai
Rotorphile.
I thought Hondas freaked out when they saw positive MAP signals? They make a "missing link" device to kill the MAP sensor CEL, maybe you need one of those.
Old Mar 31, 2004 | 09:51 AM
supermac88's Avatar
supermac88
after a lot of research it shouldn't do this unless I had over 1bar, not 5.5psi it should throw a CEL but not dump fuel which means that the ecu is in limp mode.
