What Brand for Ignition Parts?
Old Mar 29, 2004 | 12:19 PM
qtiger's Avatar
qtiger
Could also be wires.
Old Mar 29, 2004 | 01:35 PM
Hondaman's Avatar
Hondaman
Black Pearl
Originally Posted by alongtheroad
(also got the infamous p1399 DTC that apparently nobody knows what it is)
Is it best to get these parts from a Honda dealer to make sure the parts are really replacements and will fit and perform properly?
Have you tried different types/grades of gas? Have you checked your timing?
How about fuel filter and air filter? Fuel pressure??
That gives you some more things to check out if you want. Good luck and keep us posted.
Cap - OEM
Rotor - OEM
Coil - OEM (usually coils either work or they don't)
Wires - OEM or NGK
I know that the 96 Civic had a very simular problem and Honda issued a TSB on it. They replace the wires, plugs, cap, rotor and do an oil change.
I don't know if that helps or not.
Old Mar 29, 2004 | 02:02 PM
pomansouth's Avatar
pomansouth
an upgraded ignition isnt really needed until under over stock boost(8 psi or more). the reason for an upgraded ingnition system is because the higher the pressure is in the cylinder at about 14 past tdc or the normal firing point, the harder it is for the spark to jump. misfires occur because of a short or obstruction in the system from the start to the end. this is why you wont get spark when the electrode is too far away from the ground. if you upgrade the full system then you are more likely to get a more powerful spark under normal conditions and under boost conditions. you dont want too much of a spark though because the ground will actually bend out of tune and cause misfires. the farther the spark has to jump the more powerful it will be. credit given to the honda builders handbook. very informative book. read and learn these are my 2cents on this subject.
Old Mar 29, 2004 | 04:47 PM
B18_Civic's Avatar
B18_Civic
yeah msd's on stock motors rock woo hoo :chuckles: heh
Old Mar 29, 2004 | 08:42 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
I agree, usually it's something dumb like wire or fouled out plugs. But try that and then check cap/rotor
Old Mar 29, 2004 | 09:40 PM
Hondaman's Avatar
Hondaman
Black Pearl
To check the wires, you can start the car when it's dark outside, then mist some water on the wires with a spray bottle. If you see blue sparks, you probably have bad wires.
Old Mar 29, 2004 | 09:42 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Wow that sounds smart, mix water with electricity But then again i don't think anyone's died from car battery shock. You can actually lick a car battery, it'll just make you feel all weird for a while
Old Mar 30, 2004 | 12:53 AM
qtiger's Avatar
qtiger
Alternator won't kill you either, but it'll make you very very unhappy.
Anyways, I'd start with new plugs and wires and then move to distributor stuff.
Old Mar 31, 2004 | 10:37 AM
alongtheroad's Avatar
alongtheroad
Thanks for all your advice!
I guess I'll change the wires first -
I found an Import auto parts place nearby that says they sell OEM wires for Honda - as long as they call it 'OEM' does that mean I can be sure of getting the same quality part as a Honda Dealer would sell?
Thanks again.
Old Mar 31, 2004 | 10:39 AM
qtiger's Avatar
qtiger
Ask them what brand it is.
You either want something that's blue and says NGK, or comes in a bag with Honda on it.
