car aligned.. pics inside
Old Mar 29, 2004 | 09:09 AM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
With thoose settings your should not need a camber kit IMHO, however they should be able to change the toe on the car without you having to buy a kit for that.
Old Mar 29, 2004 | 09:18 AM
aero3685's Avatar
aero3685
the only thing you will need is adjustable front upper arms, or camber kits. The rear you can shim out w/a few washers. They were just trying to sell you extra stuff....im sure they know about teh washers, but they cant be liable for telling you... they gotta go by the books.
Old Mar 29, 2004 | 03:37 PM
Xplicid01's Avatar
Xplicid01
Originally Posted by llxzxll
oh and is the gunmetal part of the rim like...shiny? i know they're regular gunmetal metallic is like gunmetal with sparkly bronze flakes...which is amazingly gay...if the gunmetal w/ polished is simliar at ALL, i will definitely NOT get that and just go flat black...thanks for the info
ya its shinny, there no flakes its same color throughout. and there 15.
b16aEGcivic- o i though u meant i should post there. sorry about that.
aero3685 ive heard people tell me about washers in the rear. could u explain more..or neone... thx
Old Mar 29, 2004 | 03:44 PM
Paulll's Avatar
Paulll
Hail Bent
yep, looks aligned to me
Old Mar 29, 2004 | 05:06 PM
aero3685's Avatar
aero3685
im not sure of what size... but im sure someone knows... but the upper control arms are connected to the body w/2 bolts. If you use washers behind those, it pushes the top out, in effect adding positive camber. I would only suggest using this for ~ 2 degrees or 3-4 washers on each bolt though. If you have to use more than that, you will have to find what length the bolts are, and just get slightly longer ones than stock but that are still High quality since you wouldnt want one snapping.
Old Mar 30, 2004 | 09:11 PM
Tang's Avatar
Tang
And now ur car with a paint job....
and a carbon fiber hood. Also just a carbon fiber hood...
sweet :P
File Type: jpg
File Type: jpg
Old Mar 30, 2004 | 09:53 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
i still dont see how photoshoppin his car has anything to do with the topic... but i did my own photoshopping, not my best, but itll do for now.
good ol common SI blue, with a carbon fiber hood
File Type: jpg
Old Apr 1, 2004 | 12:50 PM
Tang's Avatar
Tang
damn it how do u put those details on the CF hood!!
o its my friends car just messing iwht him.
Old Apr 1, 2004 | 02:30 PM
NoRiCeHeRe's Avatar
NoRiCeHeRe
Dropping your car 3" would for sure qualify for some type of camber kit. You're right that they could adjust his toe alignment without a kit.
Currently I am in the same boat with my suspension. When I was rotating my tires I noticed that my tires were wearing bad on the inside of the tire. I didn't think I would need a camber kit either and I am only dropped 1.75." I was able to find a camber kit that would work for my set up. They are the OBX Racing camber kit.
Old Apr 1, 2004 | 08:45 PM
Xplicid01's Avatar
Xplicid01
well a friend of mine has a shop, and for like 150 bucks he could get me Skunk2 Front Upper Control Arms and SPC Rear Camber kit.
im going to raise my car to about 2 from 3. the wheels are biting the fenders when more than 1 persons in the car. and than get cambers installed and adjust my damn camber.
