need brake change advice
hey i was going to change my rear drum breaks but then after i took them out. i realized that lordco gave us the wrong size.. they were way too big. so i put the brakes back on and everything but now my brakes are really really soft and the car finally stops if i basically press the pedal in all the way. and the e brake works only if i pull it all the way up to the top (12 clicks). (it would have stopped around middle before, ie 6 clicks)
can anyone tell me or show me somewhere on how i can tweak my brakes so that they would grab near front part of the pedal push and tell me how to bleed my brakes?
thanks a whole lot. i'm getting the right brake shoes tomorrow
93 civic sedan canadian lx
whoops, to bleed the brakes there is a rubber capped nipple around the back of the hub, you take like a 12mm socket and open that up and let air bubbles come out, then you close it and have someone pump the brakes till theyre hard....
then open it while they apply firm and even pressure.
then close it
let them pump the brakes
open it and let the bubbles out
continue till the pedal is firm and no air releases, repeat for each wheel you worked on.
btw, the reason is air is highly compressable while fluid is nearly impossible to compress.
then close it
Originally posted by frank
thanks a lot for the quick reply.
whats a deally though...
oh ok,. i know what you're talking about there, its like a double sided piston thing.
so how do i recompress it?
and its called a wheel cylidner, theyre like 14 bucks, and they make a cool noise when you blow them off the backing plate.
ok ok . so to recap. i c clamp the cylinder. and then bleed the brakes? or do i c clamp the cylinder and put the brake shoes on, then bleed the brakes? i don't see how i can have the c clamps on after i put the shoes on? and is this recompressing the cylinder essential? what exactly does this do?, and the rubber nipple thing. is it at the top, left, bottom, right? is it pretty hard to miss?
its sort of like resetting the brakes and making them seat properly, right now the cylinder is extended to compensate for worn brakes, and also, when you remove the pads it kinda jacks some of this...
anyway, take it all apart, compress the cylinders, put it all back together, get the drum on and then the nipple is on the back of the hub i think.
