Random CEL light goes on and off
Old Mar 22, 2004 | 11:41 AM
Paul's Avatar
Paul
Eater of Rice
Default Random CEL light goes on and off
Okay, I had this problem before, but it occured infrequently. It's happened twice in the last 5 days now. (I just installed my turbo setup this week). Anyways, the car will throw a check engine light sometimes, so I'll shut the car down and pull over, and try to pull the code, but the moment I restart the car, the check engine light disappears. Anyone have any idea what it could be. I think it might be the o2 sensor. I know on the dyno the wideband could barely read my a/f ratio. The car was running pig rich 10:1 or better, the bosch wideband could only read above 10:1.
Old Mar 22, 2004 | 12:07 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
How much boost?
You realize that you're not supposed to start your car to check a CEL right? You just turn the key to the position just before you turn it on with the paper clip in the connector and then count the flashes... you don't start the car.
Old Mar 22, 2004 | 02:11 PM
Paul's Avatar
Paul
Eater of Rice
Originally Posted by westcoaststyle
How much boost?
.5 bar
Hmm, maybe that's part of the problem, either way the code is gone.
Old Mar 22, 2004 | 03:25 PM
Paulll's Avatar
Paulll
Hail Bent
Does it go on when you hit boost?
Old Mar 23, 2004 | 02:45 AM
Paul's Avatar
Paul
Eater of Rice
nope, not yet anyways.
Old Mar 23, 2004 | 03:36 PM
bambbrose's Avatar
bambbrose
do you still have your cat?
Old Mar 23, 2004 | 03:45 PM
Paul's Avatar
Paul
Eater of Rice
ahem...no
Old Mar 23, 2004 | 06:03 PM
smudge's Avatar
smudge
Do you have check valves for the MAP sensor? If so, you may need more.
I've heard MISSING LINK works well.missing link
Old Mar 23, 2004 | 06:29 PM
Paul's Avatar
Paul
Eater of Rice
No, I don't need a missing link. I'm not running an FMU or the "Hack". As I stated before it does NOT throw the code under positive pressure.
Old Mar 23, 2004 | 06:42 PM
bambbrose's Avatar
bambbrose
without a cat, I have sometimes heard of a very random CEL during longer drives and on the freeway. the CEL's you got weren't at those times were they?
