And now they strike me!
Old Aug 2, 2002 | 10:13 AM
wilsel's Avatar
wilsel
Good luck man! I can't make it to the meet this weekend, but give me a shout when you have another one.
Old Aug 2, 2002 | 10:45 AM
derf's Avatar
derf
Spec5
Originally posted by wilsel
Sounds like something's drained the battery. Are you sure that no lights were left on from in the morning? Have you tried to jump it? Even if it's the alt. you should be able to jump it, or roll start.
hah! no.
if your alternator is shot causing your battery to die. what do you expect to provide electricity for the car? Hopes and dreams?
try to jump b4 u do antyhing
Old Aug 2, 2002 | 10:49 AM
crucial Si's Avatar
crucial Si
Banned
check your distributor coil.
Old Aug 2, 2002 | 11:23 AM
wilsel's Avatar
wilsel
Originally posted by derf
hah! no.
Well if his altenator is shot how do you suppose he got to the parking deck the previous day??? Do you really think he had just enough power in the batt to make it into his parking space?
If it was that low his batt light would have been on, on his way to work.
Old Aug 2, 2002 | 11:36 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Originally posted by CivicMachina
i think you have to actually to take the door off
no, u don't have to take off the door...
just remove the door panel... and then if your is electrical.. then disconnect the cables... after that... there should be a metal bracket that holds the window... you have to slide the window in from inside the door... insert one edge first and then turn to insert the other edge... then slide in. however, prior to doing so... you will need to use a brush and remove all the broken pcs... and also if i remembered correctly.. on the metal bracket there should be a little hook or something of that sort to latch onto the new window. once you do taht... everything else should be cake... if confussed... check ur helm... it helps.
Old Aug 2, 2002 | 05:16 PM
white lightnin's Avatar
white lightnin
It was just a godamned mother****ing piece of **** battery cabl being loose. Pardon my french. I should have investigated more! Now im more pisse dthan before. At least 150 bucks down the drain. I remember when I got the new battery i tightened it down all the way and it was still a bit loose. Guess that got me in the ass. Oh well you live and learn.
