motor swap Help
Old Mar 12, 2004 | 06:10 AM
FordTuner's Avatar
FordTuner
Default motor swap Help
Hi, all
i dont have a civic right now but i used to have a 89 si, until it rusted apart. my question is from my friend who is planning on buying a 92-95 hatch and putting in a b18b... i've done many a motor swaps but they all were direct swaps... i read on honda-perf.org that the b18 will bolt in but i need the b18 tranny/axles, harness and ecu...
is this all? or do i need the fuel pump and other lines?
Old Mar 12, 2004 | 11:09 AM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by FordTuner
Hi, all
also need B series motor mounts. and proper ecu
Old Mar 12, 2004 | 03:09 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
and the other things you mentioned
Old Mar 12, 2004 | 08:25 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
You will also need the shift linkage.
Old Mar 13, 2004 | 07:35 AM
FordTuner's Avatar
FordTuner
so fuel pump too? or can i wire in the D-series one?
Old Mar 13, 2004 | 11:31 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
you don't ahve to touch the fuel pump. The only thing I would recommend is getting a gsr fuel line from the fuel filter to the rail. It has slightly largerpassages through the fittings. Pleanty of people ahve used the original fuel line with no problems. And yes, the stock pump keeps up just fine.
