How to drain/fill radiator of '00 Civic EX coupe (auto)?
Old Mar 5, 2004 | 11:41 AM
disc108's Avatar
disc108
Default How to drain/fill radiator of '00 Civic EX coupe (auto)?
are these correct?
1) Drain radiator by turning valve at bottom
2) Fill and run car for 15 min with radiator cap off. When no more bubbles appear, there is no more air in the system.
3) Done?
Old Mar 5, 2004 | 12:31 PM
Nelson's Avatar
Nelson
Administrator
Exactly
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 5, 2004 | 12:51 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
should he flow water through the system to get impurities out of it?
Old Mar 5, 2004 | 01:05 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
I would only bother if your replacing a nasty old radiator and you want to make sure there is no crud in the coolant system. There should be a coolant drain plug on the back side of the motor that you can open to drain and flush the motor.
Old Aug 24, 2004 | 07:13 PM
VtecRacer's Avatar
VtecRacer
I drained my coolant, and wanted to put the coolant back into the system. When I was filling the coolant in the radiator cap, it filled up before I was finished pouring all the fluid in.. is this normal?
I started the car and saw air bubbles coming out from time to time, but some of it dripped off the radiator cap..
Now the car appears to be ok, but how can I tell if there's any air bubbles still in the system? My temperature guage is fine. back to the way it was before.
Old Aug 25, 2004 | 04:36 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
you also need to make sure you turn your heater on to high heat and full fan.
Old Aug 26, 2004 | 04:07 PM
VtecRacer's Avatar
VtecRacer
so when I start the engine, turn the fan on full and heat
Also when I was refilling the coolant, the radiator cap filled up before I was finished pouring the rest of it in. Some air bubbles came up, so I poured a little more, but I couldn't pour the whole bottle in (I just drained the coolant and was pouring it back in). So after the fan came on I poured the rest of it in the white coolant container.
EJ8_coupe
Showroom
71
Mar 13, 2004 10:48 AM
Daniel
News & Rumors Archives
45
Aug 29, 2003 12:46 PM
hyperlite
Engine Swaps, Tech & Tuning
7
Jan 29, 2003 08:19 PM
