I installed a rear disc setup and Specialty products control arms
Old Feb 29, 2004 | 03:50 PM
ZimZimma13's Avatar
ZimZimma13
Boston Dirt Dog
I understand how that helped your camber and all, but wouldnt it also push the upper part of the tire outwards as a result? The only reason i ask is because with my drop and my 17s I had to run the rear tires at -1 degree so they wouldnt rub
Old Feb 29, 2004 | 05:27 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
Originally Posted by Hondaman
Just grab onto them with a vise grips right off the bat. It will save time and the fitting.
What kind of wrench are you using also? If you are using a box wrench, it's a waste of time. You may want to try a flare wrench if you don't want to use a vice grips.
whats a flare wrench?
i was using craftsmen 10mm open ended wrench and the wrench metal was giving
Old Feb 29, 2004 | 05:28 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
well i was worried but it doesn't push the top of the wheel ouch...
it pulls in the bottom of the wheel fixing camber.
right now i have positve camber with about a 1.5 drops
Old Feb 29, 2004 | 07:53 PM
Hondaman's Avatar
Hondaman
Black Pearl
They work awsome for getting flared fittings off. You can buy a good metric set for about $30. You can get cheaper ones for around $10-$15 in hardware store "clearance" bins.
Old Feb 29, 2004 | 07:54 PM
Civic2Scooby's Avatar
Civic2Scooby
:goodjob: I was gonna post what they were earlier and forgot..:doh:
Old Mar 1, 2004 | 09:17 AM
puffthomas's Avatar
puffthomas
JC,
Nice job on the car? Get any help Always here to help man.
Old Mar 1, 2004 | 10:09 AM
Section8Blammo's Avatar
Section8Blammo
Crazy Canoodler
Right. I did the washer trick to bring my camber into check, and it pushed the top out a little much. That's why I'm very jealous of igo4bmx right now. Nice job, and good luck with the brakes.
