Tightening E-Brake, 95 vic DX
Old Feb 17, 2004 | 09:45 PM
Iairj84's Avatar
Iairj84
Default Tightening E-Brake, 95 vic DX
Hey, I was wondering if anyone out there can help me tighten up the Ebrake on my 95 DX with Rear drums, I have seen many posts about tightening the Ebrake, and I have tried the pump method, and also the reverse method... Is there a tightening nut somewhere to tighten it up. I cant get it to catch enough to do much for me... If anyone can help it would be great!
Old Feb 18, 2004 | 07:47 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
I think there's a nut behind a little popoff cover near it.. look for a cover that you can popoff with a standard flathead screwdriver, I think it said that somewhere on a post about ebrake tightening, search for it.
Old Feb 18, 2004 | 08:41 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
take off ur armrest/e-brake cover. Lift the rear end of your car. Lift the ebrake until the first click. Tighten the nut until you feel drag in the rear wheel. HIH
Old Jul 27, 2004 | 10:26 AM
HoNdAeVo's Avatar
HoNdAeVo
I railed YOUR sister.
I just did this on my 95 integra coupe, thanks for the idea
Old Mar 23, 2005 | 02:46 PM
duder's Avatar
duder
what's this pump method? and the reverse method as well?
Old Mar 24, 2005 | 05:21 AM
JimBlake's Avatar
JimBlake
There's an adjusting nut for the cable, it's located a few inches aft of the handbrake lever. That's for cable-stretch.
There's automatic adjuster mechanisms at the wheels. It's inside the caliper for disks, & it's inside the drum for drum brakes. That's to keep it working as the pads/shoes wear down.
The pump method is for the auto-adjusters at the wheel. If you get new pads & retract the pistons too far, you pump the brakes 50 times to allow the auto-adjuster to 'catch up'. There's usually something similar for drum brakes, where you back up & hit the brakes to let them ratchet themselves into correct adjustment.
Don't use the cable adjuster to compensate for screwed-up wheel adjustment. They're for different reasons.
SHEERKON
10
Apr 15, 2005 07:49 PM
b00gers
7
Sep 5, 2003 09:22 AM
keefungliu
Mar 21, 2003 05:30 AM
VtecApprentice
Engine Swaps, Tech & Tuning
5
Feb 10, 2003 07:12 AM
kfar09
4
Oct 29, 2002 11:51 AM
