sub advice
Old Feb 17, 2004 | 07:52 AM
ofthesun93's Avatar
ofthesun93
Xplicit Illusions
Default sub advice
for all you bass fans who are wondering how hard it is to wire your own sub all you have to do i strip the passenger side carpet out and look for the ac line then drill with a 1/2 inch bit about an inch under that. If the sub is in the trunk then take out the plastic speaker covers and the storage bins and there will be hole already to the trunk to run the wire through its pretty simple just time comsuming. Then you can just run the rca and remote wires under the plastic armrest/storage thing.
Old Feb 17, 2004 | 08:21 AM
sol_guy02's Avatar
sol_guy02
its easy, there are plenty of options on which way to run wires in the sol.
Old Feb 17, 2004 | 11:23 AM
187ROCK's Avatar
187ROCK
well i just got a custom box for my sol on ebay.. to replace the rear compartments.. holds 1 12".. any suggestions of which sub?
Old Feb 17, 2004 | 11:46 AM
rtpassini's Avatar
rtpassini
already got a system, and going for my second one done in fiberglass this week.
there isnt one best sub out there.the choice is pretty much up to you.
Old Feb 17, 2004 | 11:47 AM
ikarus's Avatar
ikarus
How much money u got? If u want the bext go with JL i recommend the W6 subs. They are expensive but well worth it. 1 10" sub will blow away almost all dual 12" subs on the market both in terms or clarity of bass and output. There is simply no other woofer like it. In ur case go with 1 12" and ur car might rattle the engine out. I hope u like bass. I DO :naughty: i would recommend getting a 10" W6 b/c a 12 might be a little much. Go to ur local JL retailer and listen to em knock u will be amazed. I Promise!!
Old Feb 17, 2004 | 11:54 AM
rtpassini's Avatar
rtpassini
http://www.audiobahninc.com/products...rs/soundQ.html
thats what i have. 2 12" there crazy
Old Feb 17, 2004 | 12:50 PM
Dr. Isotope's Avatar
Dr. Isotope
Elemental e12A. Or an e12O if you have the cash.
Old Feb 17, 2004 | 08:51 PM
LostSol's Avatar
LostSol
You actually don't have to drill anything to run the power wire. In the firewall, on the passenger's side, there's a hole with a rubber covering on it. Take the rubber cover off, then just run your power wire through there. You can fit any size wire through there. As for the JLs... I don't think a W6 will fit behind the seats. I think it's a little too deep. Plus, I think they suck. They hit hard, but it's not all about SPL. I like clean bass, and I think they give you anything but. I would go with a Boston Acoustics or an MB Quart (which is what I have). Good balance between thump and clarity, and they handle buckets of power. For a 10" Boston or Quart, they'll run you $200-$250 for the woofer.
Old Feb 17, 2004 | 09:21 PM
rtpassini's Avatar
rtpassini
like i said, there isnt one best sub, where it has a gain, it will also lack.
Old Feb 18, 2004 | 08:29 AM
LostSol's Avatar
LostSol
True, true
KingPin
Aug 10, 2003 08:03 PM
CIVICFANATTIC82
92+ Civic/EL & Del Sol
May 7, 2003 08:45 PM
sierrafun
13
Apr 19, 2003 09:45 AM
95tegLS
4
Mar 14, 2003 03:13 PM
microrecord
Accord
9
Aug 8, 2002 07:18 PM
