PROblems !
Old Feb 15, 2004 | 08:06 AM
Kestrel's Avatar
Kestrel
Push to shock!
Originally Posted by honura
Ok I pulled the sparkplugs and them shits are blacker then black ! Im gonna go clean then with some sandpaper and see what happens . Yes Im gonna go buy new ones . Those bosch platinum 4 spark plugs What do you guys think of those ? Just a hype ?
I wouldn't use sandpaper, there's just too much risk of introducing some sand into the cylinder. If you're going to need new plugs anyway you should probably just go get new ones and put those in.
Old Feb 15, 2004 | 08:07 AM
PHiZ's Avatar
PHiZ
BOOST GOD
You're swapped? I think you should have included that in the first post, so people have a better idea of you setup, sorry, I don't know everyone's setup by heart.
Originally I thought it might have sounded like some bad gas. I guess you're looking at the typical swap troubleshooting, made a little easier, cause you know your timing is ok, because they car has been running.
So, spark, fuel, check wiring/grounds. Best wishes man, sorry about the hard luck lately (you had some other issues?)
-PHiZ
Old Feb 15, 2004 | 08:16 AM
honura's Avatar
honura
Seni
-PHiZ
Yeah thanks man ! I tried looking at all that everything seems to be good . Plugs are shot , filter is good , injectors are spiting . plugs are firing . AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHh f**king car . Sorry 92 civic dx HB , B18B1 swapped Gsr Tranny .. :drunk:
Old Feb 15, 2004 | 11:56 AM
honura's Avatar
honura
Seni
Ok I went and bought new plugs and it's the same shit . Starts for a sec and dies . Umm I just noticed that the car give me a small shock when I get out . Is that a sign ?
Old Feb 15, 2004 | 12:01 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Do you have any cells on?
Old Feb 15, 2004 | 12:02 PM
honura's Avatar
honura
Seni
Yeah the same ones as b4 . Nothing has changed , only thing the car will not start . :a:
Old Feb 15, 2004 | 12:09 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Ok my book says to check these:
Loose or faulty electrical connections at the distributor, coil or alternator
Insufficient fuel reaching the fuel injectors
Vaccum leak at the gasket btween the intake manifold and throttle body.
Old Feb 15, 2004 | 12:19 PM
honura's Avatar
honura
Seni
Humm I checked everything but the alt but I know thats good because It's charging the batt when The car runs for those few seconds . But if I give it gas it just dies
Old Feb 15, 2004 | 01:03 PM
Kestrel's Avatar
Kestrel
Push to shock!
Dunno if this might be a problem, but is your ECU working?
Old Feb 16, 2004 | 10:53 AM
honura's Avatar
honura
Seni
Ok I just remembered that I am using water as a sub for Antifreeze due to my leak . Now I flushed all the lines and tried starting the car again and nothing . But if I use starter fluid it will stay on as long as I keep spraying . Now AGAIN I dissconected my fuel rain with the injectors hooked up and they spray all at diffrent times like 1 then 2 then 3 then 4 " don't know if thats the pattern but useing it as an example . All fuses are good all plugs are tight all grounds are fine . Spark coming from distro . Umm ......... Batt is good alt is fine .
