Bucking...
Old Feb 11, 2004 | 08:21 AM
fbp2000si's Avatar
fbp2000si
Default Bucking...
I have a 2000 civic si and when i am driving the car will start to buck, it will loose power and then come back, it happens alot starting from a dead stop or the car was at full throttle...
Old Feb 11, 2004 | 09:56 AM
NoRiCeHeRe's Avatar
NoRiCeHeRe
:eh: :thinking:
Old Feb 11, 2004 | 10:23 AM
Section8Blammo's Avatar
Section8Blammo
Crazy Canoodler
Sounds like a spark issue maybe? Just shootin' in the dark but it sounds like you're describing a misfire. Check your plugs. Check your wires. Check the cap and rotor if those are okay. Read your plugs to see what your fuel situation is. Maybe the fuel filter could do with changing. Consult your repair manual of choice for some other simple things to check out. Good luck!
Old Feb 11, 2004 | 11:44 AM
raiden571's Avatar
raiden571
turning u inside out
just a thought, it could also be your throttle body, but the car is a 2000 and fairly new. like section said, it could also be your spark.
Old Feb 11, 2004 | 05:24 PM
randomtask77's Avatar
randomtask77
Wanderer
More often than not, it's a spark plug misfiring or something of that nature. Have you done a tune-up lately? Might as well change the distributor cap and rotor and plug wires while you're at it.
Old Feb 11, 2004 | 05:36 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
your spark is being interuppted i iwould just go ahead and replace igniter,rotor,dist. cap.,plugs, wires,.that right there should take care of teh problem h:
Old Feb 11, 2004 | 08:38 PM
honura's Avatar
honura
Seni
Yeah sounds kinda like my problem . I changed everything and it came back to life !
Old Feb 13, 2004 | 09:51 PM
spooncivicb16b's Avatar
spooncivicb16b
how many miles do you have on yourr car?
