Help Needed! Car Does Not Run!
Old Feb 4, 2004 | 05:41 AM
bluebomb's Avatar
bluebomb
Gonna be boosted '01 LS
Default Help Needed! Car Does Not Run!
Hey,
I got a 92-95 Honda Civic with a 2001 Integra LS engine, and a chipped ECU.
On sunday night i wanted to go home, but my car would not start :awais: . It was running fine for the daytime, but when i wanted to go home at night, it would not start. I turned the key to "on" and i did not hear the fuel pump fire up. I checked the fuel pressure and it was reading 0! I then proceeded to replace the fuel pump with a type-r pump. This did nothing. The car still does not run, and then check engine light still stays on. I could not find the fuse (if there is one) for the fuel pump (so if there is one, and you know where it is, let me know).
Does anybody know what else it might be. I was thinking maybe it is the ECU, but that would be expensive to just pick-up and try out. Please let me know, as i need my car for transportation.
Thank you in advance,
Johan
bluebomb007@hotmail.com
civic_eter@hotmail.com
Old Feb 4, 2004 | 05:56 AM
Wharbone's Avatar
Wharbone
try replacing the fuel pump relay.
Old Feb 4, 2004 | 05:57 AM
bluebomb's Avatar
bluebomb
where would that be?
Old Feb 4, 2004 | 06:59 AM
Wharbone's Avatar
Wharbone
Well first off, check the code and see what it says.
Another thing you can do is remove and inspect the ECU (15 A) fuse in the under-hood fuse/relay box. If that is bad, replace it. Then inspect the ACG (S) (15 A) fuse in the under-dash fuse box.
It is possible that it could be your ECU, but probably unlikely.
Here are some pictures from the service manual that might help you. They are for trouble shooting when you don't hear your fuel pump come on. You will also see a picture of there the "main" relay is.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Feb 4, 2004 | 09:53 AM
bluebomb's Avatar
bluebomb
wow!
I use to go to other boards, but this is really impressive...Thanks alot, im sure that will help. I have been having problems with my electrical system over the last few months, so it might just be it. I will check it right after work...
Thanks again,
Johan
Old Feb 4, 2004 | 11:25 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
perfect example of why HAN is such an awesome place......:exnbp:
Old Feb 4, 2004 | 12:28 PM
Wharbone's Avatar
Wharbone
Hope it helps you figure it out. Let us know when you figure it out!
Old Feb 4, 2004 | 12:50 PM
bluebomb's Avatar
bluebomb
and the response time is much better. On the other boards you have to wait for days sometimes to get a response. I will definatly keep posting and browsing here.
Old Jun 18, 2006 | 02:44 PM
waaBAAH's Avatar
waaBAAH
i know i know...this is old as hell. but i found it funny that bluebomb said han is the shit and that he will definetly post agin. his post count is still four. lmao
Cosmo M3
May 9, 2004 04:16 PM
JimCarryFanz
May 4, 2004 11:46 PM
SaviouR
Mar 26, 2004 05:49 AM
excitid
CRX & Pre 92 Civic
18
Oct 30, 2002 05:27 AM
CivicSiRacer
Track & Autocross
3
Aug 16, 2002 09:17 AM
