Rear drum question
Old Feb 3, 2004 | 12:11 PM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
Default Rear drum question
I did a search so :db:
Im trying to change my shoes but have had no success removing the cover. Do I have to take the middle nut off or should the cover pop right off??
Old Feb 3, 2004 | 12:41 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
pops right off...screwdriver and hammer are some very nice tools to remove the drum
Old Feb 3, 2004 | 12:58 PM
Hondaman's Avatar
Hondaman
Black Pearl
Some of the drum hubs are threaded to screw a METRIC bolt into. You can use a hammer and screwdriver, but you run the risk of cracking the drum or breaking a chunk out of it.
Old Feb 3, 2004 | 02:29 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
how bout a mallet?? lol
Old Feb 3, 2004 | 03:58 PM
Kestrel's Avatar
Kestrel
Push to shock!
did you put down the parking brake? just checking...
Old Feb 3, 2004 | 05:02 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Yeah, make sure the brake is off. If you look closely, you'll see two small threaded holes around the middle of the drum. You need two metric bolts (sorry I don't remember what size, probably eyeball it to one at a hardware store) and tighten each one a half turn at a time and the tap the drum once in a while with a hammer. Takes a little time, but it will pop off. The center cap does not have to come off.
Do one side at a time too, so you can check to make sure all the springs and catches are where they're supposed to be before you put the drum back one (compare one side to the other). I had good luck on mine with a good pair of needle nose pliers and an old broken straight screw driver (a chip out of one corner lets you hold the end of the springs when you stretch them and then slide them into where they need to go).
Old Feb 3, 2004 | 06:09 PM
Jafro's Avatar
Jafro
I'm made of meat!
My money's on the parking brake.
Old Feb 3, 2004 | 08:29 PM
theguy386's Avatar
theguy386
Got one side done :bigok:, Ill do the other in the morning. Thanks guys
Old Feb 4, 2004 | 11:49 AM
Andy's Avatar
Andy
Nah, getting those damn things off can be a huge ass pain sometimes. I went to bleed my '92 CX's brakes for the first time and the bleeder screw snapped on the drivers side rear (it was seized). I had to pull the whole trailing arm off and cut the E-brake cable becasue I couldn't get that damn drum off (I was in process of changing over to GS-R disks so I didn't care about the drums but I couldn't change the rear yet). I finally managed to get it off with the trailing arm clamped in a vice and 2 bolts (I took it off to try to use an easyout to remove the old bleeder screw). I ended up having to replace the actual valve inside once I finally got the drum off. Big pain in the ass!
EddieK
92+ Civic/EL & Del Sol
Aug 25, 2003 12:14 PM
jaje
News & Rumors Archives
17
Jul 15, 2003 07:57 PM
derf
6
Feb 9, 2003 05:41 PM
white_n_slow
8
Dec 2, 2002 07:16 AM
wrigh003
Accord
6
Jul 2, 2002 06:40 PM
