pressure ?
Old Jan 21, 2004 | 01:09 AM
pinoyboy's Avatar
pinoyboy
im asian
Default pressure ?
wondering about attitude changes in regards to tire pressure
does having a higher pressure in the rear promote a more neutral bias?
tried this in my car, but too salty outside to push it.
or is it the opposite?
Old Jan 21, 2004 | 06:10 AM
honura's Avatar
honura
Seni
Old Jan 21, 2004 | 08:24 AM
pinoyboy's Avatar
pinoyboy
im asian
so that the rear tires approach the limit of adhesion sooner than the front; so the car does not understeer as much
Old Jan 21, 2004 | 10:29 AM
NoRiCeHeRe's Avatar
NoRiCeHeRe
I don't believe that altitude has any effect on your tires PSI. :dunno:
Old Jan 21, 2004 | 11:07 AM
honura's Avatar
honura
Seni
Old Jan 21, 2004 | 11:08 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
i dont think altitude has an effect either... only temperature.
Old Jan 21, 2004 | 01:14 PM
Kestrel's Avatar
Kestrel
Push to shock!
Default Re: pressure ?
Typically speaking inflating your tires decreases the size of the contact patch and the adhesion limit on your tires. So I guess the short answer is no, you would want to decrease the adhesion limit of the front tires (since that's what causes the car to understeer). So you'd want to pump up the fronts.
Old Jan 21, 2004 | 01:15 PM
Kestrel's Avatar
Kestrel
Push to shock!
Altitude has a big effect, because the atmosphere pushes on the tire too. When I drove from Denver to Cleveland I needed to stop and inflate my tires in Des Moines because they dropped nearly 3 lbs.
Old Jan 21, 2004 | 07:14 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
When I autocross I run around 44psi front, 34 rear to help the car rotate, you got it backwards.
:edit: hey, folks! he's talking about attitude, as in cornering attitude. Not altitude :chuckles:
Old Jan 21, 2004 | 10:00 PM
honura's Avatar
honura
Seni
:thumbup:
