How to install Power Steering 95 civic dx
Old Jan 20, 2004 | 08:20 PM
irod87's Avatar
irod87
could i remove this rear engine subframe from the 95 ex sedan automatic that i speak of.also is it a very difficult job?
Old Jan 20, 2004 | 08:23 PM
irod87's Avatar
irod87
its a 95 civic ex sedan,he is pulling the motor and trany but i can still get the pump and wiring and pulley.will the subframe off it work?and how hard is removal...sorry for all the questions.
Old Jan 20, 2004 | 08:24 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
It's not hard to remove. The front LCA's bolt to the subframe so they have to be removed and either brace the engine or remove it (wouldn't be a bad thing to add when doing a swap, I had my engine removed to do some maintenance and change the brake system over to a GS-R setup). Unbolt the steering and the tierods and it's 4 big bolts and it's out (I used an air gun, but they shouldn't be as bad as axle nut bolts).
Old Jan 20, 2004 | 08:27 PM
irod87's Avatar
irod87
the engine and tranny are out so it should be an easy task.
Old Jan 20, 2004 | 08:29 PM
Andy's Avatar
Andy
Those parts should work fine. If he's removing the engine, just ask him to be careful of all the PS stuff and leave it in, write down or take pictures of where everything goes and carefully unbolt everything and you should be able to to swap everything over pretty simply. I remember when I was stripping my rack down there was hardline part and a sensor attached that I just threw away, but I'm not sure where that sensor would go. Might have just been a GS-R thing but I doubt it? I still say dump the PS and just use the new rack, make yourself one of these (I gotta get my web host fixed).
File Type: jpg
Old Jan 20, 2004 | 08:52 PM
irod87's Avatar
irod87
the reason i was wanting powersteering was of course to improve turning and i have 17" wheels that seem to pull on any lil grove on the road.But like i said since i can use all that stuff off of that 95 ex i can probebly get it all for like 30 bucks.so i figured it would be worth it.I figure i will work on getting everything i need together first.then i will worry about installation.
Old Jan 20, 2004 | 08:56 PM
irod87's Avatar
irod87
so from the ex i need,
Rear engine subframe
ps pump
ps belt
ps resevoir
ps pulley
ps rack
ps hoses
correct?
Old Jan 20, 2004 | 08:57 PM
honura's Avatar
honura
Seni
Wow I think andy hit it in the nose !
Old Jan 20, 2004 | 08:58 PM
irod87's Avatar
irod87
he sure did,big help,thanks man
Old Jan 21, 2004 | 09:12 AM
Andy's Avatar
Andy
ps pump
ps belt
ps resevoir
ps pulley
ps rack
ps hoses
correct?
Add the steering knuckle/universal joint (the little gold colored floppy thing that connects the steering shaft to the rack, the PS and non-PS are different) and don't forget any of the hard or soft lines and you should be good to go. Hopefully everything works out, good luck.
