Swap !
Old Jan 19, 2004 | 07:58 PM
honura's Avatar
honura
Seni
Default Swap !
Ok Ok I know this has been covered like 50 million times but I wanna be 110% sure I have everything I need !
I have a 92 civic hb DX
92 LS motor
95 GSR tranny
92 axels
92 mounts
94+ Upper drivers side mount
95 GSR shiftlinkage "Will the 92 work ?"
all Obd1 parts ECU , Distro , Injectors
Now the question is ! Will the 90 mounts work ? and Axels . ? Thanks guys !
Old Jan 19, 2004 | 08:58 PM
Civic2Scooby's Avatar
Civic2Scooby
I do not believe the 90 mounts will work, and also you need the 94+ shift linkage the 92 linkage wont work without modification.
Old Jan 19, 2004 | 09:56 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
yup. You need 94+ mounts, linkages and axles. I'm assuming you have a clutch and flywheel :thinking:
Old Jan 19, 2004 | 09:57 PM
honura's Avatar
honura
Seni
Originally posted by white_n_slow
yup. You need 94+ mounts and linkages. I'm assuming you have a clutch and flywheel :thinking:
Yeah the one on the motor now !
Old Jan 19, 2004 | 09:58 PM
white_n_slow
it's my D in a B
see edit.
Old Jan 19, 2004 | 10:00 PM
Civic2Scooby
Default Re: Swap !
92 LS motor
95 GSR tranny
92 axels <need different axles
92 mounts <need 94+ mounts
95 GSR shiftlinkage
FIXED :thumbup:
Old Jan 19, 2004 | 10:02 PM
white_n_slow
it's my D in a B
Default Re: Re: Swap !
Originally posted by b16aEGcivic
thats looking better. 94+ teg axles will do the trick.
